| Forum topic by ClintH | posted 93 days ago | 612 views | 0 times favorited | 14 replies | ![]() |
93 days ago |
Hello all, While perusing craigslist I came across a used Grizzly G1023 that the guy was asking $650. He said it was purchased about 20 yrs ago but he is a hobbiest and it has seen light use. A few years ago he upgraded to the shop fox fence and rail system. From the pictures it looks like it is in good shape. Unfortunatly its about three hours away, so I can’t just hop over and check it out. So to the questions; I have read that the older grizzlys had iffy quality especially when it came to the flatness of the table top. Is this true? Also he says it is left tilt blade, but all the info I can find on that age of saw says they are right tilt. The power switch is on the right side and the handwheel for the tilt is on the left, which to me means right tilt. Am I missing something? I would eventually like to add dust collection to it, but can’t find any info on if it has a dust port. I was thinking if I could talk him down to around $550 then it would be a good buy. Any opinions on this deal? Thanks. |
14 replies so far
#1 posted 93 days ago |
take a straight edge with you and check the table top for flatness yourself. i prefre a left tilt saw, but many WWs get along well with right tilts. quickest way to verify tilt is to look at the front of the saw and check the bevel opening in the front of the saw . right tilt: left tilt: on right tilts, the slot goes to the left as the blade bevels to 45. on left tilts, the slot goes to the right as the blade bevels to 45. check the pics he provided and you’ll know the tilt definitively. personally, a 6 hour RT for a saw that isn’t ~ 90% of what i’d want isn’t something i’d do. good luck. -- there's a solution to every problem.......you just have to be willing to find it. |
#2 posted 93 days ago |
I bought a 1 yr old 1023SL with a Mulecab sliding table, a Freud dado set, several Freud blades, and an Incra miter gauge for $550. I gladly drove 5 hrs. one way to get it. I realize this was not an everyday bargain but $650 for a 20 yr. old saw is high IMO. It sounds like a right tilt saw to me. Are you OK with that? Are you able and willing to replace the belts and deal with other issues such as arbor bearings or motor failure? Do you have 240v service or will that increase the cost? I’d be in the $4-450 range, maybe $500 if it’s really clean and quiet. I’ve learned to decide what I want, how much I’m willing to pay and then be patient. It has helped temper my inclination to be a grouchy old phart. -- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com |
#3 posted 93 days ago |
it would have to be in showroom condition at that price. 3 hours away is about 150 miles that’s over $100 in fuel. I went 800 on mine, but it is a Powermatic 66 with a new 3HP baldor motor, 54” fence and it has a full cast top. there is no wood in the saw Iron from left to right. I would hold out unless he is willing to go to 350-400 because you have to figure mileage into the final price. I would try to squeeze on him over the phone because if you drive 150 miles to look at it then he thinks he has you. if you are going to give up the space then go for a cabinet saw with a 3HP or better. remember a quality cabinet saw will be the last one you ever need to buy. also don’t be scared of 3phz. I have seen 5HP uni-saws go for 400 cause they were 3phz. in my research I have found you can buy a panel to make your own rotary converter for 200+ the cost of the used idler motor. my 3phz converter cost me 200+50 for the motor and it is a 7.5 hp that setup will run any machine up to 5HP so now I can run all kinds of 3phz machines from it. it my be a little more upfront to go 3phz but you can get heavier machines down the road for a lot less. happy hunting and be patient I searched over a year for my planer |
#4 posted 93 days ago |
http://www.grizzly.com/products/10-Hybrid-Table-Saw-with-Riving-Knife-Polar-Bear-Series-/G0715P A new one is around 800.00 sans freight. Welcome to LJ’s ClintH |
#5 posted 93 days ago |
that’s over $100 in fuel. 150 estimated miles each way is a 300 mile round trip. at 20mpg, that’s 15 gallons. at $4/gal, that’s $60, not $100. still not insignificant or am i missing something? -- there's a solution to every problem.......you just have to be willing to find it. |
#6 posted 93 days ago |
@waho6o9, Be careful with the G0715P – it’s got table mounted trunnions and not cabinet mounted ones. Might not be a big deal to some but I’ve gone through two of these saws already that arrived to me defective and I’m having a very big issue trying to get my money refunded. |
#7 posted 93 days ago |
Thanks for the info gtbuzz. I hope you get your issues resolved. |
#8 posted 93 days ago |
If you want a table saw in the 500 range think about new Ridgid 4512(they have their blade alignment issue worked out) or a used Powermatic 66. I’m big fan of Grizzly tools but their quality is much better now than it was 20 years ago -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#9 posted 93 days ago |
Thanks for the replies everyone. Sounds pretty universal to wait for a better deal. I might also just bite the bullet and get a new saw. 240V is not a problem, my garage is unfinished and the electrical panel is in the garage. I will be finishing it in the next few months and I was planing on running a few 240V outlets around the garage anyway. Oh and my truck gets around 12-14mpg, darn that big V8!! |
#10 posted 93 days ago |
Thanks Jim. The more I look at saws and research the more I am leaning towards a cabinet saw. I think my original price range was too optimistic. I am going to have to break open the piggy bank and jump to the next price bracket. All the used PM 66s that I have seen people are asking around 1200-1600. It seems people are very proud of their used tools here in the northwest. |
#11 posted 93 days ago |
Clint http://lumberjocks.com/knotscott/blog/32154 -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#12 posted 93 days ago |
“I might also just bite the bullet and get a new saw.” Well, here ya go. I got my 1023RLW in December. Looove it! |
#13 posted 93 days ago |
i’m with jim when he suggests the 4512. just because someone in another part of the country was unfortunate enough to get one of the defective units doesn’t mean you necessarily will also. nothing ventured nothing gained. buy one and see if you like it. it’s returnable if you don’t. i’m pretty sure that cannot be done with grizzlies, sawstops, powermatics or unisaws. FWIW, michael fortune, a noted band saw expert and custom furniture designer/builder, uses a ridigd bs1400 as his “go to” saw, even though he has other, more expensive saws in his shop. he doesn’t use a premium tool (the 1400 is notably the weakest of all ridgid stationary power tools) in his work. my point is, don’t underestimate the utility of a tool based on it’s price. i sold a unisaw and kept two contractor saws as they fit my space and woodworking requirements. big isn’t always better. wouldn’t it be better for the utility of your tool budget to possibly find a $400 saw (4512 less a HF “20% off any single item” coupon) and put the savings towards more tools/accessories/materials or the ”family, two kids, ........house remodel ”? just my $.02. -- there's a solution to every problem.......you just have to be willing to find it. |
#14 posted 93 days ago |
An older 1023 in good condition could be worth $500 or so IMO, but it depends in part which fence is on it. A Shop Fox Classic or Shop Fox Original fence are a plus over some of the older Griz fences. Be sure it’s 3hp single phase too….dunno if they ever offered a 3 phase version, but they did offer a 2hp version. Table flatness isn’t a big deal (within reason)...it’d take a pretty significant deviation from flatness to effect the cut. It’s likely a right tilt….the left tilt would have been a G1023SL which didn’t exist 20 years ago….the best way to tell is to look at the front handwheel’s relation to the “smiley” arc. If the blade is at 90°, the handwheel will travel to the left if it’s right tilt, to the right if it’s left tilt. right tilt: left tilt: -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3548 |
15781 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2840 |
809 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
