Hand Plane info sought
« back to Hand Tools forum
Forum topic by Milo posted 02-16-2013 08:52 PM 1091 views 0 times favorited 7 replies Add to Favorites Watch
View Milo's profile
Milo
869 posts in 3346 days
02-16-2013 08:52 PM
While I am waiting to be able to get started on my new shop, I thought I’d try and finally get serious about my hand planes. I figure the first step is to properly ID them. Below are a few pics. If you can illuminate me a bit on what they are and the proper us, I’d sure appreciate it.
A Stanley 78? With 2 irons?
Right: The one on the right is a (shoulder?) Craftsman
Left: Only says “Made in the USA”
Right: Made in England
Left: Baily #5
I appreciate it!
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
7 replies so far
View Francisco Luna's profile
Francisco Luna
943 posts in 3420 days
#1 posted 02-16-2013 09:00 PM
the upper one, take a look on this link,all the info needed:
http://www.supertool.com/StanleyBG/stan10.htm
Regarding the smoother, do you see any name on the lateral adjustment lever, that small bar under the blade?
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View Don W's profile
Don W
18754 posts in 2594 days
#2 posted 02-16-2013 09:08 PM
Use the link Francisco sent and match up according to size, but it looks like the second picture is a #4 and a #6. Bottom id 2 #5’s.
The #78 looks in good shape. Its pretty rare to find one with a fence and depth stop all together. They all should make decent users once cleaned up and tuned.
View Milo's profile
Milo
#3 posted 02-17-2013 12:26 AM
I am going to use the advice from http://www.n5ebw.com/stanley-4-hand-plane-restoration/ to restore the planes.
I will get some side shots tomorrow if that helps.
Don W
#4 posted 02-17-2013 12:36 AM
View bandit571's profile
bandit571
20247 posts in 2710 days
#5 posted 02-17-2013 12:37 AM
There was a Roy Underhill/Chris Schwarz episode a while back. Talks about what each type of plane is used for. The two #5s are either called jack planes, or sometimes called Fore planes, as this is the main plane to turn rough wood to something one can use. The #6 is a Small Jointer Plane. Can be used as a Jointer, oreven as a smooth plane to surface larger panels. The #4 size is a smooth plane, and does just that. It smooths the surface, to prep it for a finish. It is usually the last plane a board would see.
That first plane, a #78 has just one iron. The iron can be used as shown to make rabbets and such on the edge of a board. By moving the iron up front, you then have a “Bullnose Plane” that can work right up to a corner. Should have a fance ( to set how far into the edge it will plane) a depth gauge, to tell you when you are deep enough. One item to look at on these: Check for the “spur”. Looks like a four leaf clover on the side of the plane, just in front of the “Rabbet” iron’s location. Sometimes called a Knicker. It scores across the grain, when making a rabbet on the end of a board.
I have in house, all but the 78. Ask away, I might even have a picture, or three to show off.
View poopiekat's profile
poopiekat
4356 posts in 3761 days
#6 posted 02-17-2013 12:46 AM
While looking at a #78 at an antiques show, the woman behind the table saw me looking at the plane, and she apologized profusely because “the front blade and cover were missing”....$8 and I took it home. Oh, and I like Footprint planes, #4s especially. Got two or three myself.
View Milo's profile
Milo
#7 posted 02-18-2013 12:59 PM
Sorry I got delay replying. Went to Olustee Battle Reenactment and got home way later than I anticipate.
There is NO additional information on the two planes that have no identification. The smoother (L, picture 3) has an interesting feature that the back of the sole has a protrusion the that the handle sits on.
The other plane (R, picture 4) only has the word “Footprint” on the lever cap.
Thanks for all the info!
