Building Clock
Forum topic by docspencer posted 02-16-2013 12:21 PM 744 views 0 times favorited 6 replies Add to Favorites Watch
View docspencer's profile
docspencer
360 posts in 1967 days
02-16-2013 12:21 PM
I’ve got a 1” thick piece of white oak I though I’d use to make a clock. I’ve got 2 questions:
1) How do I go about figuring how deep to rout the cavity for the movement?
2) What’s the best to actually rout out that cavity? I”m thinking a thick jig and top bearing bit. Any better ideas?
I’d appreciate any ideas!!!
View helluvawreck's profile
helluvawreck
31340 posts in 2888 days
#1 posted 02-16-2013 12:40 PM
You need to get the movement first and by looking at the movement you can figure out the depth. The movement may have directions with it to show you what the cavity will be. You can probably probably get out most of the waste with one or more forstner bits. Maybe a combination of forstner bits and router bits. It’s all going to depend on what sort of cavity the movement requires so getting the movement seems to be step one.
helluvawreck aka Charles
docspencer
#2 posted 02-16-2013 01:04 PM
Thanks, helluva. That makes perfect sense.
View JoeinGa's profile
JoeinGa
7736 posts in 2029 days
#3 posted 02-16-2013 02:02 PM
If you’ve never done a clock before, make sure you get one with a long enough stem so you dont end up with paper-thin wood where it comes thru the hole. (The stem is what the hands mount on)
Arts and Crafts stores like Michaels and Hobby Lobby usually carry a variety of types with varrying stem lengths.
Once you getthe hang of it and want to do more clocks, check out garage sales, and flea markets for battery operated clocks that are cheap. This past Christmas I made 4 clocks for the guys that worked in the same dept. The clock works at Hobby Lobby were $9.95 each. I happened to find 4 clocks new at WalMart that had a long enough stem that were on closeout for $3 each. That was like buying one and getting 3 free to me.
docspencer
#4 posted 02-16-2013 02:31 PM
Again, that makes sense, thanks. One movement I”m looking at is 2-3/16’’ Wide x 2-3/16’’ High x 9/16’’ D, so I think I have plenty of room for the face thickness – 7/16” minus how much I want the movement to be inside of the back of the clock. Does this make sense?
I like the idea of salvaging movements from old or cheap clocks.
JoeinGa
#5 posted 02-16-2013 02:49 PM
Without putting a ruler to it, I’d say that sounds pretty close. You want the stem to protrude just enough to get the thin washer on and be able to tighten the nut without a bunch of threads poking out past the nut.
docspencer
#6 posted 02-16-2013 02:56 PM
Oh, yeah. I forgot about that washer. I went ahead and ordered that movement. If things don’t work out, I can always take another piece of scrap oak and start again.
