| Forum topic by rf58 | posted 123 days ago | 612 views | 0 times favorited | 14 replies | ![]() |
123 days ago |
Topic tags/keywords: under floor heat dust collection electrical outlets question I need some ideas—- -- rf58, Illinois |
14 replies so far
#1 posted 123 days ago |
Sooner or later you will likely get a blockage somewhere in your dust collection lines. You’ll want to be able to unblock the line without resorting to a jackhammer . . . -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#2 posted 123 days ago |
if you ever get a blockage or want to move around where your machines are…. -- Rob, Sault Ste. Marie, Ontario |
#3 posted 123 days ago |
Congratulations on the new shop. Best wishes -- Lynn "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford |
#4 posted 123 days ago |
Once you put it in concrete it’s there to stay. You will probably be OK with a center location, but it sure makes any changes to the layout tough. Also, if you put in 4” and find you need 6”....well, you’re kinda screwed. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#5 posted 123 days ago |
My Father-in-Law just did this very thing…He hasn’t used it yet, though, because the new shop/house is not finished, so the holes are just taped-over right now to keep debris out… BUT, I suspect it is not a horrible idea, and will probalby serve him well once he gets the shop set-up…I trust his judgment because: -- I'm strictly hand-tool only...unless the power tool is faster and easier! |
#6 posted 123 days ago |
I like the idea in general but have one concern not already mentioned. Dust collectors don’t like 90 degree bends because it significantly decreases air flow. I think you will need a minimum of 4 90* bends to get from the DC to the TS. These can be long sweep elbows (or 2 45 degree elbows separated by a foot or more) which will help, but you will need to dig deep enough below the floor level to accommodate the additional radius. Anyhow, check to see how many CFM you will lose for each bend you need to include. You might also want to include an option for above the table collection. HTH -- Art |
#7 posted 123 days ago |
Under floor dust collection may be a serious problem for you the difference in temperature between ground temperature that typically is around 60 degrees and humid warm air being drawn through the system may cause condensate to form on the inside of the duct causing the fine dust to collect and plug the system. As far as the in floor heat it is great as long as you don’t try to use it for a few hours at a time once you get the floor warm you will need to keep it at temperature. -- The faster I go The be-hinder I get |
#8 posted 123 days ago |
I wanted to do what you are thinking about but my HVAC consulted with some experts and they told him they had never heard of it being done and advised against it. Clogs and bends were their reasons (all noted above). I ended up not doing underfloor electrical either (I only had a few days to work, including the radiant tubing). I was coming from very small space and knew however I initially placed the machinery it would probably change as I got used to the new space (I was correct). I think code might dictate that the outlets had to be on a riser (e.g. I couldn’t mount them flush because it was “slab on grade”) and as such I would end up with a live outlet sitting there…as much in the way as an extension cord is. but we have a few sparkies here that can opine there. Under floor wire chase would be a good idea although you can probably get the same result with a chase above the floor just as well. I love the radiant heat but it was a PITA to install. It was cold and the tubing was stiff. It took my SWMBO and me 2 full days of backbreaking work (my plumbing guy and my concrete guy hated the staples so the tubing was zip-tied to the re-wire every 18 inches or so…and because suitable zip-ties were only available in 5” lengths, once we were finished with the tubing we had to go back and snip all the tails off otherwise they would pop through the concrete (the picture is “pre-snip”). We didn’t use an “uncoiler” because my plumber tried a cheap one once and thought it was a bigger job than “man-handling” the coil…500’ rolls of 5/8” that will do everything possible to uncoil itself and leave you swearing…and when at the end of a run the coil has to be flipped without “kinking” the tubing (kinks are a NO NO). When we were finished and I later did my basement I rented a Rehau un-coiler thinking it couldn’t possibly be as bad as he said…I was correct. I’d suggest you do the same (it will cut your time in half or more). I know part of the problem was the cold weather and the resulting stiffness of the tubing. |
#9 posted 123 days ago |
I’m opposed to putting anything under or in a concrete floor. No expansion is possible. Repairs will require a jackhammer. Why are you opposed to having exposed ductwork, wiring or piping? Maintenance must always be a factor. |
#10 posted 122 days ago |
MrRon…with radiant the jackhammer option is very limited (look at my picture above). I don’t even want to drill into it (and my home inspector knew all about it…the basement posts are actually secured to the floor with epoxy in the holes rather than securing them the normal way. As much as I tried to direct the tubing away from the post footings, he knew that all kinds of things can happen in a floor pour/finishing job. The last thing you want is to knick any part of that tubing. I could envision a sturdy “chase” built below. But it’s going to have 3-4 inches of concrete on top of it (limiting how wide it could be)...I have to wonder whether it would be worth the cost of doing it right. |
#11 posted 122 days ago |
have you considered a crawl space so you can access the under floor options. I would think it would be cheaper to frame a floor than pour it plus it would be softer under foot. where I live any thing over 24×24 has to have a footer below the frost line. so I would think poured walls and a framed floor would be the best option for DC, wiring and any changes after the fact |
#12 posted 122 days ago |
WOW LOTS OF RESPONSE. THANK YOU ALL WHERE DO I START WHAT I PLAN IS A TROUGH / CHASE ( 10” X 30” x 20” deep ) JUST IN THE CENTER OF MY FLOOR . USING A (PARALLEL BEAM FLAT WAYS ) FOR A BLANK TO COVER IT with holes cut in it( and one to match with no holes ) and room to coil up the electrical and air hose cord beneath it should i want to have a party or someting. . I HAVE A flat MAP FILE CABINET /TABLE EXTENSION FOR MY TABLE SAW ON WHEELS. -- rf58, Illinois |
#13 posted 122 days ago |
Andrew Pitts has DC in his floor but I think it’s the second story portion of his shop. Not sure. You may want to contact him. I wanted to run my DC in the floor too but the county rejected it. Not sure why. I would like to have an elevated floor made of wood with the DC underneath the flooring but pretty settled in now and won’t be making that dramatic of a change. Good luck. -- Sorry the reply is so long. I didn't have time to write a short reply. |
#14 posted 122 days ago |
sorry, I don’t know the details…I just know he did it, and he hasn’t tested it yet. -- I'm strictly hand-tool only...unless the power tool is faster and easier! |
| Forum | Topics |
Woodworking Skill Share
8847 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15984 |
Hand Tools
2101 |
Jigs & Fixtures
501 |
Wood & Lumber
2909 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
