Workbench Thoughts - Ikea Countertops?
Forum topic by Lsmart posted 99 days ago 1043 views 0 times favorited 13 replies Add to Favorites Watch
View Lsmart's profile
Lsmart
91 posts in 509 days
99 days ago
Topic tags/keywords: workbench oak beech birch
Hi All,
A quick question, I am looking at building a workbench for myself and while looking for lumber sources I came across the idea of using Ikea butcher block counter tops for the top, they are available in beech, birch or oak, 72 inches long, 25 inches wide and 1 1/2 inches thick. Price $199 canadian. Compared to a top from Lee Valley ($499 with hardware but 2 inches thick) this seems like a pretty economical way to go. Wondering if anyone has any thoughts on whether this would be a good idea and if not why not? Thoughts appreciated.
13 replies so far
View waho6o9's profile
waho6o9
2928 posts in 749 days
#1 posted 99 days ago
Glue two together and wrap around a 3 inch border. Not sure if anyone’s done that
but it has been discussed.
View Julio Alonso Diaz's profile
Julio Alonso Diaz
165 posts in 1052 days
#2 posted 99 days ago
Hi I thought I was the only with this idea, poor of me hahaha, Im only joking. Yes I agree to get the ikea tops, that is the way I took to my workbench, I chose birch. I think it is a good idea, as the buddie has said I glued two together to obtain a thicker workbench top. Maybe it is cheaper because it usually goes to kitchen and they are not dead flat but since the workbench is to work I was not looking for the most precise surface, although you can get better making adjusments with a scraper plane or cabinet scraper.
Cheers !
-- El hombre que amo la madera. http://www.youtube.com/user/julioyaldonza?feature=mhee
Lsmart
#3 posted 99 days ago
I had thought to glue it to a piece of 3/4 birch ply for the extra thickness and wrap it with a birch border (as I already have lots of birch, thought I’d rip it down the middle and rum through my planer to flatten.
View Rick M.'s profile
Rick M.
1507 posts in 552 days
#4 posted 99 days ago
Don’t glue it to plywood. Wood changes size, plywood doesn’t… immovable object + irresistible force = KAPOW!
-- -- Rick M.
View DouginVa's profile
DouginVa
428 posts in 445 days
#5 posted 98 days ago
Agree, never glue plywood like that. However, MDF might be good. It’s more stable, dead flat, and will add the much needed weight to a workbench top so it’s not scooting around the floor on you while you’re planing, etc.
-- Just a man with his chisel.........
Lsmart
#6 posted 98 days ago
Trying not to make too many mistakes with this one…. that’s why I’m asking you folks. Thanks for your reply’s.
View Bill White's profile
Bill White
2608 posts in 2132 days
#7 posted 98 days ago
Lsmart, ya better watch that “rum through the planer”. Messes up the bearings. Better way…”rum through the planer operator”. :))
Just couldn’t help myself…..........
Bill
-- bill@magraphics.us
View CplSteel's profile
CplSteel
140 posts in 336 days
#8 posted 91 days ago
never put rum through the planer. Whiskey always gives you a better finish. Though beer can suffice if you need to thin it.
Back to the OP. I wonder if the Ikea butcher block is actual butcher block or MDF/Particle board with a “butcher block” veneer. Not to say that it couldn’t work. But if it is just finished MDF I would recommend gluing up some Ply or MDF and topping with Masonite. It won’t look the same but it will perform the same as “butcher block” and be much cheaper.
EDIT I went ahead and looked it up online, it says it is solid birch/beach/oak. It comes a bit wide so I think you can find out how true they are when you rip it.
View joeyinsouthaustin's profile
joeyinsouthaustin
519 posts in 244 days
#9 posted 91 days ago
I have cut and installed Ikea BBlock, and it is solid wood. Have you considered bamboo. It is Very durable, hardly moves, and all kinda Green, and used to be CHEAP!!! Btw if you use flooring glue, you can glue it without the expansion problems.
CplSteel You should use a jointer, not a planer, if you want to drink your Bourbon straight. ;)
-- Who is John Galt?
View shampeon's profile
shampeon
520 posts in 355 days
#10 posted 91 days ago
The old tops that were 1.25” thick birch for $60 made me stop and think, but at $199 for only 1.5”, for around the same money you can buy some nice hard maple lumber and laminate it yourself with money left over.
Using 8/4 lumber and the same dimensions, you’ve got about 25 board feet of lumber. For that same $200 you can buy lumber up to around $8 a board foot.
View Dakkar's profile
Dakkar
253 posts in 99 days
#11 posted 91 days ago
That’s an interesting idea, anyway. Here’s the Ikea specs on it: http://www.ikea.com/us/en/catalog/products/40057853/
Lsmart
#12 posted 91 days ago
@shampeon, I hear what you are saying, but 8/4 hard maple is hard to come by and expensive in my part of the world (I live in softwood land and far from the big city) also my time is worth something so if I can save a couple of days of work buying something pre-made it may be worth it… going to the city next week so I’ll check out the tops and price out some maple when I’m there. Thanks for all your thoughts folks!
View Hucklberry's profile
Hucklberry
2 posts in 508 days
#13 posted 89 days ago
I have used Ikea BB for a variety of projects, mostly in the kitchen, of course, but I’ve built a couple of small work benches with left-over scrap. I also built a router insert for my table saw out of it. I like it a lot. It’s easy to work, stable and flat enough for my purposes. I’m about to build a drill press table out of a chunk of it. Sometimes you can find cheaper pieces in their “as-is” dept.
