Edge banding MDF top
Forum topic by sry posted 76 days ago 259 views 0 times favorited 8 replies Add to Favorites
View sry's profile (online now)
sry
29 posts in 144 days
76 days ago
Topic tags/keywords: question edge banding mdf workbench
I’m in the process of building a version of the FWW Getting Started in Woodworking bench and want to modify it a little by wrapping hardwood around the MDF top (3/4” MDF doubled up into a 1 1/2” top). Looking for advice from the forum experts about how to go about this.
I’m thinking right now of just routing the edge of the top into a tongue and grooving my hardwood banding material to match. Am I on the right track, or does somebody out there have any better ideas?
I should point out that this is my first woodworking project, and my skills and tool collection are still growing…
-- Steve -- Cleveland area, Ohio
View Tony Z's profile
Tony Z
150 posts in 326 days
76 days ago
I think that will work. On my Torsion Box I screwed my edging to the MDF and plugged the holes with a contrasting wood.
-- Tony, Ohio
View brianinpa's profile
brianinpa
941 posts in 259 days
76 days ago
Sry,
Knickknack posted a small oak table project and he provided an excellent answer to your question: it’s about 1/2 way down the post. This may be what you are describing. If all else fails, rabbet the harwood banding, the glue the banding to the mdf.
Goodluck!
sry
76 days ago
Thanks guys. I’ll try it out and post the results when I post the project.
View sIKE's profile
sIKE
605 posts in 290 days
76 days ago
You could use biscuits and glue…will help align everything and the glue will make it stay.
sry
73 days ago
I’ve successfully applied a strip of hardwood around the edge of my MDF top, and intentionally left it a little proud of the surface, thinking I could trim it flush a little later.
My new question is: what’s the best tool for the job? It seems like a larger job than my little block plane should handle, so maybe a larger plane like a #4?
View motthunter's profile
motthunter
1234 posts in 335 days
70 days ago
mdf is made from sawdust and glue. Edgebanding it is easy as can be as glue sticks well to glue. Fasteners like brads help hold it till the glue dries, but if you clamp well, even that may be unnecessary.
-- making sawdust....
motthunter
70 days ago
Steve, to flush trim, you can use a flush trim bit on your router.. Or you can use a plane if you want to do it by hand. There are also many router table set ups that can help do this.
teenagewoodworker
2134 posts in 305 days
69 days ago
ya you could use a flush bit on a router. might get a bit hairy with the bit out in the open and everything. if the edgebanding is 3/4” you could use a block plane for a #4 or #5, 6, 7, 8. really any plane. i would use a #4 though because a #7, 8 might get a bit tiring
Bookmark And Share This Page
