| Forum topic by Damian Penney | posted 419 days ago | 1770 views | 0 times favorited | 39 replies | ![]() |
419 days ago |
419 days ago |
1HP ~ 750 watts So: Now, you can argue about motor efficiency, but a 15 Amp circuit at 240V should support a 3 HP motor under load. Make it a 15 Amp slow-blow fuse to support higher motor starting currents. Circuit breakers are inherently slow-blow. -- "Find out what you cannot do and then go do it!" |
419 days ago |
Perfect, thanks :) -- I am always doing that which I can not do, in order that I may learn how to do it. - Pablo Picasso |
419 days ago |
I’d go 20amp or 30amp. Circuits should not be loaded for more than 80% of rated breaker amps for continuous load. You might want to consider pulling 10guage wire and using a 30amp breaker for it. Some 3hp motors pull 19amps and require a 30amp circuit. I run my 3hp grizzly cabinet saw on a 30 amp breaker. Remember the breakers main purpose is to restrict how much juice you can pull from the power company through the circuit and the wire size, breaker, and receptacles need to be matched up properly to prevent electrical fires. -- DaveH - Boise, Idaho - “How hard can it be? It's only wood!” |
419 days ago |
20A it is then. -- I am always doing that which I can not do, in order that I may learn how to do it. - Pablo Picasso |
419 days ago |
normally I would have said 13 amp is a bit too low and16 amp might be more the thing but if you want to take it to twenty then so be it.Alistair -- excuse my typing as I have a form of parkinsons disease |
419 days ago |
Hi Damian It’s very difficult to answer your question. You see, to produce a 3HP that is 750×3 = 2250W (actually, 1HP = 746W but you are not planing to design the motor, don’t you…so 750 is good enough) Now, for those 3HP OUTPUT the input is always bigger and it depends on the motor efficiency to convert electric power to mechanical work and always it will be less than 1 (or less than 100%) There is a PDF file “comparison of 10 table saws”, all of them with 3HP but the Ampere is varying from 12A (high end saws…and expensive) to 18A (low end saws…and cheap) Usually, the Amp is written on the name-plate but if its missing, I would take DaveH’s advise and go with 20A….to be on the safe side Regards |
419 days ago |
I am running a 3hp shaper off a 20amp 220v outlet. Typically from my experience, 2hp can be 15amp, but wire for 20 to be safe, 3hp 18 amp startup, so go 20, 30 if you want to be safe but more costly, 5hp requires 30amp 10ga wire. |
419 days ago |
Just stick in a 20 amp breaker assuming your wiring is correct for the load. 20 amps wont hurt anything as I doubt if you will be running other than your DC at the same time. Commercial shops—- please ignore my advice . -- A mind, like a home, is furnished by its owner |
419 days ago |
Be safe use 15 amps I have 35 years of electrical work -- <<<<<< I will not stop until I get it right. >>>>>>-- |
419 days ago |
if i recall electrical motors of this capacity, there may be a capacitor on it…. start up is the usual breaker tripper, so if the motor plate indicates 15 amp, it may or may not trip the breaker… |
419 days ago |
GMan, why do you think 15A is safest? I thought that if your circuit can supply what the motor wants then it doesn’t matter how far and above that you go because the breaker is there to protect your wiring, not your appliance. -- I am always doing that which I can not do, in order that I may learn how to do it. - Pablo Picasso |
418 days ago |
I think wiring size vs. amperage is the critical link here. Here are what I consider safe wiring sizes. -- Carl Rast, Pelion, SC |
418 days ago |
Damien: -- Carl Rast, Pelion, SC |
418 days ago |
I used a 20A breaker, and 12 ga. wiring, for my 3HP General 650. Remember… A circuit breaker protects the line wiring, not necessarily the powered object. We don’t swap breakers as we plug in different items around the house, do we? This is a BIG, often repeated misunderstanding. There is normally a fuse or breaker in the powered object itself for protection of the device. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
418 days ago |
15 amps I would rather reset a breaker than damage something -- <<<<<< I will not stop until I get it right. >>>>>>-- |
418 days ago |
My, my, lots of comments on this one. In my initial reply, the numbers were all conservative. 70% is actually rather low efficiency for a motor; many sources use as high as 85% for RI motors. Brush-type universal motors run considerably less efficient, initially and after lotsa brush wear. 70% is very conservative, even for a universal motor. 1 horsepower is actually 745.6999 watts if you wanna be precise. 750 is only +0.13% error, why quibble? And, again, it leads to a more conservative answer. But I haven’t heard anyone question the most basic assumption; voltage! At my humble abode, the line-to-line voltage actually reads about 238V. I have seen as low as 220 in some locations. Now, subbing 220 V into my original equations yields 14.6 A which might be running close to the limit on a 15 Amp circuit. Basically, if you already have a 15A, 240V circuit, use it and put in a slow-blow fuse, you’ll be fine. If you are running a new line, by all means, use 12 AWG and fuse it for 20A. You’ll be plugging something else in for sure. -- "Find out what you cannot do and then go do it!" |
418 days ago |
I recommend that you go to one of the box stores and in the electrical section of that store you will find a book called “Wiring Simplified”. It will give you everything you (an average layperson) should need to know about wiring. The gauge of wire is determined by two factors: distance and load. The shorter the run of copper the greater the load it can carry this is due to resistance on the wire (aka the longer the load runs on the wire the hotter it will get). The larger the gauge of wire (remember the number gets smaller the larger the wire gets) the more heat it can handle and therefore the larger the load. I built my16×24 shop this last year and I put in wiring to handle 240volts at 20 amps with ~30ft runs. I dropped two circuits one for dust collection and one for operating machinery (you know the cuttin stuffs). From what you have described a twenty amp circuit should be fine. Once again this depends upon the distance you are from the breaker box and how much amperage you will draw. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
418 days ago |
417 days ago |
Carl – ya know, there’s still room on that panel for a couple more controls… :) -- "Find out what you cannot do and then go do it!" |
417 days ago |
EE – Nice to know we’ve all got a sense of humor. Thanks! -- Carl Rast, Pelion, SC |
152 days ago |
sIke had a good point 266 days ago and I have a question now regarding distance. I hope that some of you are still paying attention. I have to make a run of about 100 feet from the panel to the garage where my 3HP Unisaw is located. Does this distance dictate a heavier gauge wire and breaker than the 12AWG/20amp suggested? Do I need to run 10AWG? -- sel |
152 days ago |
Carl, you forgot a few toggle switches and a volume control LOL. Go with the 20amp circuit provided you are dedicating this line for only you TS. If you are running other things such as a DC, then do your calculations to figure the entire load and wire accordingly. Sel, assuming that you are trying to provide for all your shop tools and perhaps lighting I’d suggest a 60-100 sub panel. For example Schd 40 1 1/4 run would be more than enough with a #6 wire (Blk,Red,Wht) and #10(Grn) with a 60 amp breaker to matching subpanel and give you future room to add a circut. I’d leave a pull cord in the pipe if you intend to do so… |
152 days ago |
CedarFreakCarl, You forgot a large Variac knob… the Key to overall control… :) :) -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
152 days ago |
Hello Damian, We use in Europe on 220v a 16 amp for a 3hp table saw. Success Schummie. -- Greetings from the Netherlands. |
152 days ago |
I am in Los Angeles. Is Schd 40 code compliant for subterranean electrical runs? -- sel |
152 days ago |
The Schd 40 is a gray electrical pipe in the electrical dept of your borg store. It should be buried a minimum 18”. Think of electricity as water. The longer the run, due to friction, the pressure drops off. The bigger the pipe the greater the pressure. With electricity the friction is resistance. Hopefully (keeping it plain as I can) this helps. Good luck. |
152 days ago |
My basic rule of thumb is to wire for a lot of capacity and use NEMA starters with heaters to protect the motors. |
151 days ago |
Thanks. My concern was the drop of ampacity due to the length of the run and to the number of wires in the conduit. I guess you all feel that 6AWG THHN is of sufficient size that even with 4 wires in 1 1/2” conduit the amount of heat generated will be insignificant. At the risk of pressing my luck here, whadda you all think of 8AWG? Safe, or should I stick with 6? I do have the Wiring Made Simple book (green cover), very old, but electricity hasn’t changed that much. Carl, -- sel |
151 days ago |
duh, what “on”...? -- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die. |
151 days ago |
Don’t know how LONG your run is… #6 would definitely be SAFE… #8 would also be safe depending on the run… The longer the run, the bigger the pipe wants to be… That’s my guess anyway… -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
151 days ago |
My run is about 100 feet -- sel |
151 days ago |
My handy dandy Sq D motor calculator shows a 3 hp at 230v single phase at 17 amp, #10 wire, 35 amp breaker. Voltage drop is an issure for length of run and higher loads. At 100 feet, I’d go at least #8. National Electrical Code requires a single disconnecting means to disconnect al the power in a seperate building. Using a subpanel is the proper way to do it. -- Debt is nothing more than the 21st Century's form of slavery. |
150 days ago |
Carl, the EE panel needs some meters, at least voltage and current, and frequency would also be cool. Maybe you could do it with an oscilloscope so we could check each phase as well. Oh, I forgot, knowing the power factor is also interesting. -- Joe |
142 days ago |
I just had an electrician install a sub in my shop. He pulled #6 through 1 inch PVC about 50 feet. No problem. All of them were single conductors. No Romex or anything like that. In my shop, I’ve run 30amp breakers with #10 wire for the 240v outlets. I’ve got #12 and 20amp breakers for everything else. I ran the 30amp breakers and bigger wires ‘just in case’. A little more expensive but I won’t have to worry much about power needs. If you can afford it, get a 60-100amp subpanel out in that shop. You won’t regret it one bit. -- Matt - My Websites - http://www.bestinwood.com - Hand Tools :: http://www.workshopgarage.com - Small Shops |
142 days ago |
Sounds good! -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
42 days ago |
Hey Lumberjocks, I’m new to this forum and not sure i know what I’m doing or am in the right forum to even ask a question but I’ll give it a try. Tell me if I am wiring my PM 2000 right. 3hp 13amp motor, 240 volt, plug has 3 wires, black, white and green for ground. I put on a 100 amp panel in my shop to run all my toys. I ran a 10/2 wire on a 30amp 2 pole breaker to the PM 2000, black to black, white to red and taped the white wire red to indicate hot, green to ground. Do I have it right? This saw was given to me 1 year ago by an old man who bought it new in 07 for tearing down an old barn and doing some chores around his place. The saw was still in the crate when he showed it to me in his garage. We did a swap for me tearing down his barn he gave me the saw. He passed away a few months ago and i want to treat this saw like a piece of gold and not burn it up wiring it wrong. Any help would be greatly appreciated. Thanks |
42 days ago |
You got it ;-)) -- Debt is nothing more than the 21st Century's form of slavery. |
42 days ago |
One bit of hard information. My 220V/50Hz/3hp (Irish) Robland X-260 saw motor was fitted with 16A slow blow fuses, and these seemed to be fine in that i never blew one. On the other hand i (unthinkingly) ran it from a 13A fused domestic socket for a while at first. It would run off that if you were careful starting it, but would pop the 13A fuse at the drop of a hat. In addition it would produce light arcing occasionally between the plug pins and the socket, although i only found out about this when i noticed light burning on a plug pin. Don’t skimp on the cable, because the voltage drop and effect on the motor will increase the amps drawn. I can’t remember for sure, but think a 3hp single phase motor like this is rated at about 14A at full load, although this could be 10% out either way. I’m not sure, but i think you’d probably find that too that it would spike quite a bit above this on start up for a few seconds. (hence the slow blow fuses)... ian -- Late awakener.... |
42 days ago |
The code says 17 amp full load for 3 hp at 230v, reality, probably 15.5-16. #10 cu wire, 35 amp breaker. Probably have to go to 40 if the 30 doesn’t hold. Standard fuse will never ever hold a motor starting unless it is way over sized. Motors starting requires slo-blo type fuses. Dual elemnt fuse if you are using them is 25 amp. -- Debt is nothing more than the 21st Century's form of slavery. |
| Forum | Topics |
Woodworking Skill Share
2813 |
3776 |
247 |
896 |
212 |
Woodworking Trade & Swap
593 |
Coffee Lounge
2279 |
LumberJocks.com Site Feedback
507 |
