TS Pulley Upgrade
Forum topic by Hermando posted 02-14-2013 06:34 PM 6904 views 1 time favorited 7 replies Add to Favorites Watch
View Hermando's profile
Hermando
75 posts in 3031 days
02-14-2013 06:34 PM
Hello All,
I am planning some upgrades to my Craftsman contractor TS. I plan to replace the Zinc cast pulleys with new machined steel pulleys or balanced cast iron. Is there big difference in performance from either. I also am interested if there is an advantage to using a double belt pulley vs a single. Such as the set up of Twomartinis.
http://www.flickr.com/photos/74108677@N00/381437857/
I can order the machined pulleys online $30-$40 shipped or buy locally the cast iron for $20 at a bearing shop.
Appreciate the input.
7 replies so far
View toolie's profile
toolie
2148 posts in 2862 days
#1 posted 02-14-2013 09:04 PM
i have two emerson built TSs, one a ridgid 2412 with a ribbed OEM belt and the other a 113 series c-man (like that pictured) with two machined pulleys (one on each of the motor and arbor) with a link belt. the c-man is just a touch smoother than the ridgid, which i believe has it’s OEM CI pulleys. i’d go machined pulleys and single link belt. such a set up should provide outstanding service for you.
Hermando
#2 posted 02-14-2013 09:07 PM
Oh Well I got it all figured out. I thought there might be some actual user experience with double pulley belts for a contractor saw.
http://www.americanfurnituredsgn.com/tablesaw_tune.htm
Cheers
Hermando
#3 posted 02-14-2013 09:27 PM
Thanks for the response Toolie, I will take your advice. A treasure of info
View Grandpa's profile
Grandpa
3261 posts in 2909 days
#4 posted 02-14-2013 09:52 PM
The cast pulley can spread and the belt will or can slip. The belts grip on the sides and should never tough bottom of the groove. I don’t think you will need the second belt. Smoothness is related to trueness.
View knotscott's profile
knotscott
8172 posts in 3609 days
#5 posted 02-15-2013 12:40 AM
Another good option is the serpentine belt/pulley set for Ridgid saws that fits many of the older Craftsman contractor saws too….$28.50 shipped.
http://www.ebay.com/itm/Ridgid-Craftsman-Table-Saw-Serpentine-Belt-and-Pulley-Kit-Belt-417J-816439-3-/200765837090
View Joe Andrews's profile
Joe Andrews
69 posts in 2233 days
#6 posted 02-15-2013 07:45 PM
I replaced the cast pulleys on mine and it did make a difference. But I could actually see some wobble in the cast pulley on the arbor so they definitely needed replacing. The link belts helps a lot more, especially if the saw has been sitting a long time with the stock belt under tension..
View jak77's profile
jak77
18 posts in 2175 days
#7 posted 02-16-2013 04:14 PM
By what I am seeing in the pic you posted it appears I have that same saw. Mine was purchased in the mid-60’s by my father. I recently swapped pulleys for machined pulleys and installed a link single belt. Made a huge difference. Miles smoother.
I then swapped the original 1hp motor for a new 1.5 hp. Again a huge step up.
