Pocket screws to attach upper bookcase to lower deck?
Forum topic by Lee Barker posted 02-14-2013 06:03 PM 1127 views 0 times favorited 4 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 2753 days
02-14-2013 06:03 PM
Suppose you have a lower cabinet with a solid wood top and a bookcase above. You’d like to locate or attach the upper to the top.
I have used dowels (via dowel centers) and screws from below (not so good going into end grain of the face frame).
What about a pocket screw hole precut in the backside of the stile where it terminates at the solid wood top? Have you tried this?
If this would work, it would be enough to locate the bookcase, but not enough for transporting the two as one piece. In that case, if your 5.2mm back had a lower nailer, there could be pocket holes on the backside of this.
Curious what you’re thinkin’.
Kindly,
View greg48's profile
greg48
593 posts in 2661 days
#1 posted 02-15-2013 03:34 AM
Lee,
I came up with a remedy several years ago joining a top to a solid wood topped base unit. I found at Rockler’s some tapered keyhole fittings (http://www.rockler.com/product.cfm?page=341&site=ROCKLER) Inletting the hardware into the uprights of the top and hogged out a little to fit the head of the round head screws, all I had to do was sink four screws into the top of the base unit, align the top over the pocket holes and push the top unit back until the tapers tightened against the screw heads. The screws are adjustable so that you can have the top unit draw down at the back edge of the base unit. It’s plenty strong to hold the top unit on and you only have to tap the top unit forward to remove it for.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View Moron's profile
Moron
5032 posts in 3797 days
#2 posted 02-15-2013 04:17 AM
do it
if you can make an instrument
your gut is almost always right
View vipond33's profile
vipond33
1405 posts in 2401 days
#3 posted 02-15-2013 04:19 AM
I’ve always liked dowels (with rounded tops) as locators in two piece loose assemblies. I take the time to machine thread for bolts if I want security and a tight fit.
Transporting is better in two pieces IMO as there is always too much stress involved otherwise (wood and personnel).
gene
-- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome.
404 - Not Found
2544 posts in 2872 days
#4 posted 02-15-2013 12:48 PM
A lot of stuff I make may have veneered mdf sides tongued into a solid face piece, with a solid timber top – so I would only fix it at the back to allow for movement.
Simple metal joining strips bridging the rear of the top and bottom pieces at each end will prevent it from moving or toppling forward.
When you are putting the top piece on, place a piece of cardboard on the top until its in position to prevent scratching the top of the base cabinet.
If this is in an earthquake zone, you may have to do something more substantial.
