What to clean while changing planer knives?
Forum topic by JesseTutt posted 02-14-2013 05:55 PM 713 views 0 times favorited 1 reply Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2352 days
02-14-2013 05:55 PM
Topic tags/keywords: delta planer delta 22-540 planer knives
I have the old Delta 22-540 12” planer. I wish I had a better one, but it is what I have.
I got several chips in the current knives so it is time to switch them out with new ones I have on hand.
I plan to do the following during the process:
  • blow out the machine with the air hose
  • wipe down the gib (?) and its screws with lacquer thinner (it is what I have on hand)
  • wipe out the grove that holds the blades with lacquer thinner
  • wipe off the entire cutter head with (you got it ;-) lacquer thinner
Is there anything else I should clean, inspect, lubricate?
1 reply so far
View Bill White's profile
Bill White
5149 posts in 4202 days
#1 posted 02-14-2013 07:24 PM
Are the bearings good? Belts? Tables slicked out? Fence aligned properly?
I presume that the “blowing out” process includes the motor and switches.
Add a light lube to the gib screws, dry lube to the cutter head, wax the tables, blah blah, blah.
Bill
-- bill@magraphics.us
