Reciprocating handpiece for Dremel Fortiflex (9100-21)
Forum topic by pdrakos posted 02-14-2013 08:44 AM 5262 views 0 times favorited 0 replies Add to Favorites Watch
View pdrakos's profile
pdrakos
2 posts in 2164 days
02-14-2013 08:44 AM
Hello everyone!!
First time in this forum, so please ignore any mistakes or stupid questions as I’m an inexperienced woodcarver :)
so here is the thing, I was searching over the internet for a reciprocation handpiece (nothing in specific), that could be attached in my Dremel Fortiflex-9100-21 rotary tool and be used with chisels for wood curving. I understand that in US might be a different model of the Dremel, so you can have a look over the web, as linked above for Dremel Fortiflex.
With the Following specifications:
Rated power input: 300 W
Voltage: 230 V
Weight: 1,50 kg
No load speed: 0 – 20.000 1/min
Fortiflex is more or less same as Foredom. I have found this Foredom Chisel handpiece for my Dremel Fortiflex,
but I don’t really know whether it would work as i need it, to use chisels. Would it be needed a different shaft drive than what I have now? The one I have is a standard “key-tip” drive shaft. I’m also attaching a pic in order to be more detail about the driving shaft. Thanks in advance, any response will be much appreciated.
0 replies so far
