Veritas dowel former
Forum topic by nwbusa posted 02-14-2013 06:30 AM 4425 views 0 times favorited 4 replies Add to Favorites Watch
View nwbusa's profile
nwbusa
1021 posts in 2308 days
02-14-2013 06:30 AM
Interesting! Up until now, the only dowel plate I was aware of was from LN. Here’s a new player in that space:
http://www.leevalley.com/en/wood/page.aspx?p=70555&cat=51&pb=1#pb
I might have to make a trip over to LV this weekend. Like I need an excuse.
-- John, BC, Canada
nwbusa
#1 posted 02-14-2013 07:07 PM
Here’s the LN version. It’s $15 more than the Veritas but gives a few more options for dowel sizes.
-- John, BC, Canada
View vipond33's profile
vipond33
1405 posts in 2519 days
#2 posted 02-15-2013 04:09 AM
They work, but unless you go in and follow through absolutely vertical you will ovalize the dowel. A close fitting & long follower hole directly underneath will guide it for you.
Though they have been used for centuries it’s easy to make a mess of things with these devices.
gene
-- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome.
View Loren's profile
10476 posts in 3669 days
#3 posted 02-15-2013 04:16 AM
I made a dowel plate for reducing some 3/8” dowels
I already had for a test project I made using smaller
metric drills in a construction boring machine.
While the doors turned out fine, the dowels pounded
through the plate came out crookeder than they
had started out and it did not instill confidence in
the general method of using a plate and mallet
to make dowels.
Oh – and General and/or used to make a dowel plate and
you can buy them on ebay for under $20.
View Straightbowed's profile
Straightbowed
717 posts in 2320 days
#4 posted 02-15-2013 04:17 AM
Im using the bandsaw dowell jig it works great use a fine tooth blade and tha dowells are perfect but fixin to experiment with tablesaw dowell jig next good nite
-- Stevo, work in tha city woodshop in the country
