How do you accurately and consistently set your table saw blade to 45 for mitered corners?
Forum topic by Kade Knight posted 02-14-2013 03:22 AM 6022 views 1 time favorited 20 replies Add to Favorites Watch
View Kade Knight's profile
Kade Knight
62 posts in 2117 days
02-14-2013 03:22 AM
Topic tags/keywords: question
I’d like to hear everyone’s ways of consistently setting their table saw blade to 45 for mitering corners of boxes, frames, etc. It seems that no matter what I do, I always have to cut practice pieces, readjust, cut, readjust, cut, readjust…...I just want to set it once or readjust once for perfect miters! HELP!
20 replies so far
View Manitario's profile
Manitario
2654 posts in 3059 days
#1 posted 02-14-2013 03:33 AM
get a good set of set-up blocks, or a protractor or once you know you’ve made a 45 deg. cut cut yourself a block at exactly 45 deg and keep it for reference.
View jumbojack's profile
jumbojack
1685 posts in 2800 days
#2 posted 02-14-2013 03:36 AM
for a long time I used an artist plastic 45 degree triangle. This Christmas I received Wexley, so now I use that.
View waho6o9's profile
waho6o9
8487 posts in 2752 days
#3 posted 02-14-2013 03:41 AM
http://www.incra.com/product_miter1000hd.htm
When you take the side movement out of the miter gauge and
have it running at a right angle to the blade your joinery will improve a lot.
It did for me anway.
Building a sled is helpful as well. You can search LJ’s in the top right part of the site and
you may get something like this:
http://lumberjocks.com/search_results?cx=016283335483199634424%3A4na88symhay&cof=FORID%3A9&safe=high&q=Miter+sled+for+table+saws&sa.x=14&sa.y=12
And welcome to LJ’s Kade!
View Loren's profile
10477 posts in 3823 days
#4 posted 02-14-2013 03:58 AM
Make a jig. Leave the blade at 90. A jig allows you to reference
the cut from the outside face of the miter.
There are electronic devices for setting perfect 45
degree blade tilts, and other mechanical ways to
do it. In making cuts however operator error,
miter gauge slop and weirdness of the table top
can be factors.
View mbs's profile
mbs
1657 posts in 3116 days
#5 posted 02-14-2013 04:12 AM
Do you have some kind of friction, like sandpaper, to hold the piece firmly against the fence?
Some other thoughts
1) See if your miter saw is more repeatable.
2) Get close and clean it up with a shooting board.
3) Use a trimmer to clean up miter
-- Sorry the reply is so long. I didn't have time to write a short reply.
View longgone's profile
longgone
5688 posts in 3484 days
#6 posted 02-14-2013 04:25 AM
I use a Wixey digital angle gague and it is dead on accurate. I have used it to set miters on over 120 boxes and have excellent results. A clean and sharp blade is also important.
My Incra HD1000 miter gague is also a key factor when adjusted properly.
View MrRon's profile
MrRon
5141 posts in 3419 days
#7 posted 02-14-2013 06:49 PM
I use the Wixey digital gauge to set the blade. For miter cuts, I use the miter gauge with the blade set at 90°.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3334 days
#8 posted 02-14-2013 07:37 PM
I have the Incra 1000HD and its great. But anytime I need critical miters, I remove the sacrificial fence I keep on it. Over time, the wood of the sacrificial fence does warp and prevent wood from sitting accurately against the fence.
To align, I use a square to get the blade perpendicular to the miter fence. Then, I test it by making a regular hexagon out of same length wood segments. Inaccuracies are compounded and multiplied by the larger number of miters…so it’s easy to fine-tune the setup when creating a multi-sided polygon. Interior angles of a hexagon are 120 degrees, so set the detents of the miter gauge to 30 or 60 degrees for the miters.
-- jay, www.allaboutastro.com
View b2rtch's profile
b2rtch
4863 posts in 3224 days
#9 posted 02-14-2013 08:30 PM
Use a home made sled, you do not have to adjust the angle every time, only once.
-- Bert
View ToddJB's profile
ToddJB
8273 posts in 2306 days
#10 posted 02-14-2013 08:35 PM
I was under the impression the Wixey gauges only worked on vertical planes… they can also work on horizontal?
-- I came - I sawed - I over-built
View History's profile
History
399 posts in 2157 days
#11 posted 02-14-2013 10:42 PM
Use a miter saw, it’s the more appropriate machine for the job.
View GaryL's profile
GaryL
1099 posts in 3006 days
#12 posted 02-14-2013 10:57 PM
I assume you mean the bevel of the blade. For this I’m with Greg and Mr. Ron. Wixey gauge
For miters, IncraHD1000
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View SamuraiSaw's profile
SamuraiSaw
515 posts in 2140 days
#13 posted 02-15-2013 01:59 AM
”Use a miter saw, it’s the more appropriate machine for the job.”
The appropriate tool for these type of miters is a table saw with a crosscut sled designed to accomodate a 45 degree bevel. I use a Wixey to confirm the 45 degree bevel and a well tuned crosscut sled to make the cuts.
-- Artisan Woodworks of Texas.... www.awwtx.com
View gfadvm's profile
gfadvm
14940 posts in 2866 days
#14 posted 02-15-2013 03:10 AM
For my boxes , I tilt the blade to 45 using my Wixey digital angle gauge. For miters like for a picture frame I have a cheap old miter gauge that I tweaked to EXACTLY 45 and then locked it down and never change it. I use another miter gauge for angles other than 45.
Cosmicsniper
#15 posted 02-15-2013 03:15 AM
My $400 miter saw is worthless for that application. It’s for crown molding when I use caulk to cover the gaps and to chop down long boards so my more accurate table saw can give better and cleaner cuts.
