Square recommendation plz
« back to Hand Tools forum
Forum topic by Belg1960 posted 02-14-2013 01:36 AM 1417 views 0 times favorited 9 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1054 posts in 2938 days
02-14-2013 01:36 AM
Topic tags/keywords: question
Guys/ladies, I’m looking to buy a quality square with a fat blade like the Woodpecker version and wonder if I could get some feedback on any similar style version.
Is this tool worth the money and are there any similar style tools available. Thanks much, Pat
-- ***Pat*** Rookie woodworker looking for an education!!!
9 replies so far
View Loren's profile
9765 posts in 3521 days
#1 posted 02-14-2013 01:45 AM
I’m a little concerned that the lines don’t wrap
around the thick edge on that square.
I do have a lot of squares I’ve acquired over the years
and the ones I use most are a 12” combo square
(have a Starrett but also have a cheapy and the
cheap one was simple to tune to be accurate
enough for woodworking), a 4” square a lot
like this one# ,
a Veritas saddle square , and a
Veritas sliding square.
I build cabinetry and furniture mostly.
I am actually on the lookout for a metric square large
enough to lay out holes in 24” deep cabinets. I know
Woodpecker makes something like that but I’m not
sure the price is worth it to me.
View ShaneA's profile
ShaneA
6879 posts in 2471 days
#2 posted 02-14-2013 01:49 AM
You can grab a vintage or even newer Starrett off ebay reasonably priced, if you keep an eye out.
Belg1960
#3 posted 02-14-2013 01:52 AM
Loren, I have an 8” starrett combo square which I use all the time. Its my go to square. I also have an 18” version which I bought second hand and it is not square, so I would love to hear how to tune this one. I did not know that was possible. Thanks Pat
View mbs's profile
mbs
1622 posts in 2813 days
#4 posted 02-14-2013 01:59 AM
I like the woodpecker quality. I carry there 6” in my shop apron and bought their large framing square to do machine setup. It was expensive but worth it to me. I have a Starrett 6” combo and 12” combo that aren’t as square as I like.
-- Sorry the reply is so long. I didn't have time to write a short reply.
#5 posted 02-14-2013 02:01 AM
You need a thin file that can get in there and you can
file down one of the other end of the sliding part. You
just draw a line on a board and flip the square, take
it apart, file a bit, put it back together and check until
it flips square. I suppose on an 18” square you should
check the ruler part first to make sure it’s not bent.
Belg1960
#6 posted 02-14-2013 02:43 AM
Loren, you won’t believe this. I went down to check the ruler for trueness,took it out of the head and removed the spring and locking screw, when I did that a tiny splinter fell out. The ruler is atraight as an arrow, re assembled the tool and did the line test and its dead on. I bought this tool at least 2 years ago and just cursed the seller this whole time for selling me a “bad” tool and all it needed was a little tlc and to ask the right question. Man I feel stupid!!
#7 posted 02-14-2013 02:44 AM
Ha!
View Lee Barker's profile
Lee Barker
2170 posts in 2723 days
#8 posted 02-14-2013 02:51 AM
I’m not sure, Pat, how thick you need the blade. I am a big fan of the Nobex Quattro (I own 4 of them, three different lengths) but the blade is a little flexible.
You can see them here as well as elsewhere.
Kindly,
Belg1960
#9 posted 02-14-2013 01:18 PM
Lee, I appreciate the link. I was looking for something with at least an 1/8” blade maybe even a little thicker I find myself that I always put too much pressure against lighter blades. I want something long enough that I can use it to accurately crosscut panels.
MBS, I appreciate the response and am seriously considering the 1281 purchase, but might go with the 24” t square. Which do think will be of better use for the above described procedure?
Thanks guys for the help. Pat
