End vise wood thickness to hold bench dogs?
Forum topic by JesseTutt posted 02-13-2013 09:05 PM 1296 views 0 times favorited 5 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
853 posts in 1984 days
02-13-2013 09:05 PM
Topic tags/keywords: workbench vice bench dogs
I am building the wooden part of my end vice. I was given the metal screw part. I plan to use round 3/4 inch bench dogs. How thick of a piece of hard maple do I need to be able to withstand the pressure caused by tightening two bench dogs? Anything over about 1 3/4 inch requires me to laminate two pieces together.
5 replies so far
View nwbusa's profile
nwbusa
1021 posts in 2160 days
#1 posted 02-13-2013 09:07 PM
I used 8/4 maple for my vise chop and it’s held up fine.
-- John, BC, Canada
View grfrazee's profile
grfrazee
388 posts in 2013 days
#2 posted 02-13-2013 09:09 PM
I would agree with nwbusa – anything under 8/4 is asking for trouble.
-- -=Pride is not a sin=-
View PurpLev's profile
PurpLev
8534 posts in 3522 days
#3 posted 02-13-2013 09:15 PM
technically I’d aspire to go 3x the width of the dogs which would be 9/4 (or 8/4 to simplify the math).
if you only have 1 3/4 you can definitely try that without having to laminate, or just look around for a cutoff piece from some local shop that will be thicker.
you can also always laminate sideways.
JesseTutt
#4 posted 02-13-2013 09:35 PM
I could face laminate up two pieces to make something 9/4 thick. I would just need to make another trip to pick up some more maple.
PurpLev, I not sure what you mean by laminate sideways. Would you elaborate?
Also, a follow up question. Should I center the bench dogs in the wood?
PurpLev
#5 posted 02-13-2013 09:46 PM
one way to laminate (probably the most obvious) is to use 2 boards one in front, one in back (as in workbench->piece-1->piece-2->vice face) another way to laminate is the ‘other way’ (?) as in one board above the other, and use more boards (more smaller pieces) – think butcher block. that way looking at the vise from the top you only see 1 ‘wide’ board so to speak
and yes, you should center the dogs in the vise
