| Forum topic by noone | posted 126 days ago | 1033 views | 0 times favorited | 37 replies | ![]() |
126 days ago |
How is this edge made? Is this a 1” roundover bit?
37 replies so far
#1 posted 125 days ago |
if you refer to the top , that’s an ogee -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#2 posted 125 days ago |
Link to the bit? |
#3 posted 125 days ago |
just an example: http://www.leevalley.com/US/wood/page.aspx?p=30188&cat=1,46168,62157 -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#4 posted 125 days ago |
It kind of resembles a raised panel bit used for making cabinet doors, but, applied to the table top edge. It looks cool, but, you can find table edge bits that have a nice edge too. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#5 posted 125 days ago |
I agree with PurpLev ogee and you vary the depth of cut. |
#6 posted 125 days ago |
Thanks. Is there a quality difference between Lee Valley bits and Freud bits? |
#7 posted 125 days ago |
I personally don’t have experience with LV bits, just knew they had a good photo sample of that bit and the pattern. I only used Freud bits and they are quite good. Whiteside also makes good bit. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#8 posted 125 days ago |
PurpLev- Do you think that is only a 1/4” radius roman ogee bit? I don’t know, seems bigger and chunkier in the pic, but it’s hard to tell….... |
#9 posted 125 days ago |
Don’t know what the radius is from the pic, but you can do that with a roundover bit by using a smaller bearing to get the quirk at the bottom. The image is deceptive because the profile is routed on the front and back edges giving it the appearance of an ogee, but I’d put money on it being a roundover witha top and bottom quirk. -- Never trust a man in winklepickers |
#10 posted 125 days ago |
if that top is 3/4”-1”, than the 1/4 radius seems just about right. (the depth of the cut is 21/32 on the LV bit specs) you can check other mfg. they might run slightly different radii/depths -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#11 posted 125 days ago |
Another way to get a similar effect is to use a roundover bit with a smaller bearing, though in the picture above that is pretty clearly not a straight up constant radius like a roundover. -- Brian T. - Exact science is not an exact science |
#12 posted 125 days ago |
It’s definitely and ogee and might be more than one board, a stack molding. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#13 posted 125 days ago |
Sorry guys that is not an ogee. That is a qtr. bead, not to be confused with a qtr. round. Most likely done with router. That’s what I would do anyway. It also has a stacked edge. JB |
#14 posted 125 days ago |
cabmaker- That’s what I was thinking. Is it this 1” radius bit http://www.freudtools.com/p-146-beading-bits.aspx with a 1/4” of the bottom of the bit coming out of the router table and then stacked on top of another piece of wood staggered in 1/4”? I just bought a board of 8/4 to do this. Am I on the right track? |
#15 posted 125 days ago |
That looks like an edge bead to me too. -- Bondo Gaposis |
| Forum | Topics |
Woodworking Skill Share
8847 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15984 |
Hand Tools
2100 |
Jigs & Fixtures
501 |
Wood & Lumber
2909 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
