Parts for chisel handles
« back to Woodturning forum
Forum topic by RussellAP posted 02-13-2013 05:02 PM 1420 views 0 times favorited 9 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2160 days
02-13-2013 05:02 PM
Morning Jocks!
I would like to know where you can get the metal bushings for lathe chisel handles. I want to turn my own handles and make them thicker so my arthritic right hand can hold them easier with less fatigue.
I can’t seem to find parts though. I can find chisels without handles all day, but no bushings to fit them up in the handle.
9 replies so far
View John Voloudakis's profile
John Voloudakis
12 posts in 1811 days
#1 posted 02-13-2013 05:14 PM
What do you mean by ‘bushings’? If you mean the ‘ferrule’, the metal part that goes around the base of the handle to keep the wood from splitting, an easy approach is to cut off slices of copper pipe in the diameter you want to use, and fit them over a tenon turned to the end of the handle.
There is an article on Doug Thompson’s site on how to make handles. It describes use of brass nuts to make ferrules too, as well as some options for ones you can buy.
Hope this helps,
-John
View waho6o9's profile
waho6o9
8070 posts in 2450 days
#2 posted 02-13-2013 05:18 PM
Some one gets brass or bronze tubing from the big box store and
makes his own.
I forget his name to give credit to, but the results were professional
looking.
The plumbing section has compression fittings and other items that
would work well.
View Wildwood's profile
Wildwood
2204 posts in 2008 days
#3 posted 02-13-2013 05:36 PM
You can buy ferrules from Craft Supplies or Packard Woodworks just check sites for sizes & prices.
I just use copper tubing couplings cut in half. Tubing cutter makes life easier than hacksaw.
-- Bill
View bondogaposis's profile
bondogaposis
4529 posts in 2225 days
#4 posted 02-13-2013 06:34 PM
I use 1” copper pipe from the big box store.
-- Bondo Gaposis
RussellAP
#5 posted 02-13-2013 06:47 PM
I can do copper. I guess I should get some and make the handle to fit it. Thanks guys.
View PurpLev's profile
PurpLev
8534 posts in 3522 days
#6 posted 02-13-2013 06:50 PM
+1 on copper tubing from the hardware store, comes in a variety of sizes (1/2, 3/4, etc)
View lumberjoe's profile
lumberjoe
2894 posts in 2122 days
#7 posted 02-13-2013 07:36 PM
Depending on the size – bigger brass air tool connectors and plumbing fittings. Brass turns like wood with wood turning tools on a lathe. Put it on, chuck it up, turn the threads off, and sand it smooth.
View ghost5's profile
ghost5
302 posts in 1805 days
#8 posted 02-13-2013 10:55 PM
I just posted one I did that I used a copper plumbing cap instead of tubing. Simply take the cap and drill a hole the size you need centered in the end then glue in place. I rough up the inside to help the glue hold.
-- Tommy, http://www.followingghost.com
View ShaneA's profile (online now)
ShaneA
6879 posts in 2472 days
#9 posted 02-13-2013 11:21 PM
You can just google it, there are suppliers out there. LV has them, ebay usually has a seller or two with them.
