Garage door insulation
« back to Coffee Lounge forum
Forum topic by robbi posted 77 days ago 348 views 0 times favorited 10 replies Add to Favorites
View robbi's profile
robbi
76 posts in 492 days
77 days ago
Topic tags/keywords: question insulation
I’m not sure if this is the right spot to put this question but…oh well. I saw somewhere (I think it was on here) that someone put insulation in their garage door. It looked similar to my garage door and I thought, hey, what a great idea, I can do more woodworking in the winter if I can get it warmer in there. So I went out and bought some insulation and some duct tape (the doors are metal) and put insulation in each panel and taped on all sides. The duct tape didn’t hold well at all. The next morning I had a pile of duct tape on the floor where it came loose. So I went out and bought some “gorilla” tape. It is holding much better, but I notice it may give out soon too. So…my question….is the person I saw with the insulation on this web site and if you are….what did you use to hold it in? Or….does anyone else have any ideas?
-- robbi
View SteveKorz's profile
SteveKorz
1419 posts in 250 days
77 days ago
(I’m assuming you bought foamboard insulation for it)
If the insulation was foamboard, I would assume you could tack it in with some liquid nails adhesive. I wouldn’t think you’d need a lot, maybe four dabs- one in each corner, maybe one in the middle. It would take the “duct tape” look away from the inside, too. They make all kinds of liquid nails for different applications, make sure and not just buy one or it may not hold. Read the tube and make sure you have the right one.
-- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17)
View MrWoody's profile
MrWoody
238 posts in 311 days
77 days ago
I used construction adhesive and it held for over 10 years. It was still holding when I replaced the door with an insulated one.
-- If we learn from our mistakes, I'm getting a fantastic education.
View ajosephg's profile
ajosephg
99 posts in 97 days
77 days ago
The foam board insulation on insulated from the factory doors is held on with adhesive.
-- Joe
2081 posts in 558 days
77 days ago
There is a “foam board” adhesive out there. Try the “big boxes”.
That’s what I used. Next time I will just get them foam sprayed to combat moisture.
View northwoodsman's profile
northwoodsman
53 posts in 283 days
77 days ago
I insulated my doors about 4 years ago. I used the blue foam board and doubled its thickness. I cut it on my table saw so it was nice and straight. Since my door has “flanges” or “rolled edges” on the top and bottom of each section, I cut each piece to the exact width but made it about 3/8” taller from top to bottom. I then flexed the piece as I was putting it in and they snapped into place. No adhesive was needed. Like I said, this was done 4 years ago and they are as tight today as they were the day I installed them. I helped my neighbor do his doors as well. It also keeps the shop/garage cooler in the summer when the sun is beating down on the doors. Good luck.
-- NorthWoodsMan
View DaveR's profile
DaveR
233 posts in 257 days
77 days ago
Several years ago I insulated my 16’ garage door for my shop. The door is supposed to be an insulated door but I think that just means you can’t see through it. Anyway, I bought 4-4×8 sheets of 2” pink foam and cut them to fit the height of the door space. I fastened them to the garage door with thin battens and sheetrock screws into the metal frame. Then I hung a sheet of plastic over the all and let it run down on the floor. At the bottom I laid a couple of 2×4s to keep the plastic tight to the door.
A little air does seep in around the sides but it isn’t much. My heater needs a bit of fresh air anyway. the shop is certainly warmer and the heater doesn’t run nearly as much as before.
The first spring after putting the foam up, I took it down again so I could open the door. The next year I didn’t get around to doing that and found it stayed much cooler in the garage with the faom there so I haven’t removed it again. Fortunately my wife is very accomodating about the shop. She says, “we have a driveway for the cars. There’s too much expensive cast iron in the shop to bring wet and salty cars in anyhow.”
-- Quantum materiae materietur marmota monax si marmota monax materiam possit materiari?
robbi
76 days ago
Well, sounds like my first mistake was buying the wrong kind of insulation. That’s okay though, I have a wall I need to do too, guess I’ll go buy the foam stuff. Thanks for all the responses, I think I will try NorthWoodsman’s advise and try to do it without adhesive, sounds easiest. Thanks again everyone.
-- robbi
View Jimthecarver's profile
Jimthecarver
224 posts in 322 days
76 days ago
I needed to do the same thing to mine. I went to Lowe’s and purchased 1” rigid foam board cut to fit and just slipped it into place.
The garage is so much cooler in the summer and warmer in the winter…cost was about 20 bucks, well worth it. Although I used a straight edge and knife to cut it…those pesky little foam floaters coming from the TS was not somthing I wanted to deal with.
Good luck to you!
-- A duck that brags on his own pond, soon swims alone.
View Dadoo's profile
Dadoo
1557 posts in 527 days
76 days ago
One thing also that I did to mine was to glue on a dry erase board for jotting notes, etc. No sense in wasting good wall space right? Another plus is that the dry erase board is steel…so magnets stick to it real well! Now there’s a secure place to post my plans too!
View John's profile
John
55 posts in 330 days
76 days ago
Hi Robbi,
I bought 2” foil faced expanded foam from a big box store. Ripped it down with the table saw and used caulking to adhere it. Used blue painters tape as clamps till it dried. It made a bid difference in the winter. Good Luck.
John
Shop
-- The answer to life, the universe and everything is .........42!
Bookmark And Share This Page
