Planer tripping circuit - FIXED
Forum topic by Sandra posted 02-12-2013 09:05 PM 3314 views 0 times favorited 23 replies Add to Favorites Watch
View Sandra's profile
Sandra
7207 posts in 2076 days
02-12-2013 09:05 PM
Topic tags/keywords: planer ridgid question
Howdy,
I tried to start my Ridgid 13” thickness planer two days ago and it immediately tripped the circuit. It was at the cold end of my shop, so I wasn’t too concerned about it.
I rolled it closer to the heater and cranked up the heat overnight. Next day, tried it again, letting it run for a second or two at a time and then shutting it off again. I did this numerous times, but each time it runs past about 5 seconds, it trips again.
Today is day three. The shop has been above 10 deg celcius/50F for two days, and still it won’t run past 5 seconds.
No doubt I need more power to my shop, but I was running it no problem last summer. The shop rarely gets close to freezing , and I keep the heat running whenever I’m going to be out there.
Any suggestions? Getting frustrated.
-- No, I don't want to buy the pink hammer.
23 replies so far
View Monte Pittman's profile
Monte Pittman
29233 posts in 2339 days
#1 posted 02-12-2013 09:09 PM
You said you have heat on when you’re out there. If you’re running a space heater it could be overloading circuit.
View PurpLev's profile
PurpLev
8535 posts in 3649 days
#2 posted 02-12-2013 09:17 PM
what kind of heat are you running in there? electric? if so, that is what is tripping your power – the heater+power tool (+lights + etc?)
View MrRon's profile
MrRon
4771 posts in 3244 days
#3 posted 02-12-2013 09:22 PM
Either there is a big power demand resulting in lower than normal voltage or you are using a too small extension cord. Is the space heater on the same circuit as the planer and are you running the heater at the same time?
View Clint Searl's profile
Clint Searl
1533 posts in 2362 days
#4 posted 02-12-2013 09:56 PM
You probably have a 15 amp breaker on a 14 ga circuit, and the planer is pulling more amps than the circuit can handle. If there’s room in the panel, you can add a 12 ga line on a 20 amp breaker.
Make sure the planer is OK by returning it to HD and getting a replacement before upgrading the wiring.
View unisaw2's profile
unisaw2
209 posts in 3036 days
#5 posted 02-12-2013 10:02 PM
Ditto from above. Start by turning everything off that is on that circuit and see if the planer will run. If this is on a 15 amp circuit it needs to be the ONLY thing.
-- JJ - Northern Illinois
View JoeinGa's profile
JoeinGa
7736 posts in 2007 days
#6 posted 02-12-2013 10:07 PM
If you are using an extension cord, first thing is take the extension off and try plugging the planer directly into the wall. And if you ARE using an ext cord, it needs to 10 gauge and no more than 40 foot long.
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2857 days
#7 posted 02-12-2013 10:16 PM
Sandra with the machine unplugged
turn it a few times by hand then try it.
Jamie
edit; sorry I just reread it and it has turned
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View nwbusa's profile
nwbusa
1021 posts in 2287 days
#8 posted 02-12-2013 10:30 PM
10 gauge seems a little excessive. 12 gauge should be plenty adequate.
-- John, BC, Canada
Sandra
#9 posted 02-12-2013 10:36 PM
Hmmm – I had the heater off, but maybe it’s still pulling power. I’ll give it a try in the morning.
Thanks. I’ll let you know how I make out.
View DocSavage45's profile
DocSavage45
8559 posts in 2843 days
#10 posted 02-13-2013 02:33 AM
Sandra,
all good advice.
What is the amperage of your planer? My table saw requires one seperate circuit.
1500 watts of powerfor electric heaters
P=E/I and reversed. light circuits in most instances are 15 amps. walls run at about 20 amps new wiring?
Has this happened before? May be bearing problem in jointer? Do you have ground faults installed?
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Carey  Mitchell's profile
Carey Mitchell
116 posts in 1960 days
#11 posted 02-13-2013 02:45 AM
I looked on the HD website and the planer model currently listed is a 15 amp machine. If you have ordinary wiring, it is likely a 15 amp circuit – the planer should trip the breaker at start-up. If not, the breaker is defective.
If a 20 amp circuit (look on the breaker), and it worked before, the breaker could be bad – they do go bad. Fortunately, they are cheap and easy to replace.
nwbusa
#12 posted 02-13-2013 03:13 AM
I run this same planer on a 15A circuit and it doesn’t trip it at startup or any other time.
-- John, BC, Canada
Sandra
#13 posted 02-13-2013 12:14 PM
Okay, so without getting too sappy, I just want you to all know how much I appreciate the help. There is no way on G’s green earth I’d get any projects done without the assistance here.
I plugged the planer directly into the outlet with nothing else on. Same thing as before – circuit tripped.
Then Jamie’s comment came to mind. It was turning wasn’t it?? So I unplugged it and tried to turn the blades by hand. No go. The motor was running before, but nothing in fact was moving, hence the circuit problem. A sip of coffee and I noticed a little red button near the blades. Gave that a push and lo and behold I could turn the blades. Plugged it back in and voila! But when it stopped, it seemed to come to a sudden stop and the red button was back out again.
A few more sips of coffee, a head tilt, a chin scratch and then the thought crossed my mind that it was pretty dangerous for the blades to be exposed like that. And then the lightbulb came on. DOUBLE DUH! The last time I used the planer, I took off the dust hood. The dust hood apparently keeps the red button depressed so that the planer runs. Evidently it’s protection for morons like me!
So suffice it to say, I put the dust hood back on and it works great.
Without this site, I probably would have called an electrician, or tried to get the planer serviced or who knows what else.
Hats off to you, have a great day!
Sandra
View DIYaholic's profile
DIYaholic
19620 posts in 2676 days
#14 posted 02-13-2013 12:49 PM
Glad the issue has been resolved.
We have ALL had many a forehead slapping, “Duh” moment!!! Just be sure not to hit yourself hard enough to do any permanent brain damage (too late for me)!!!
View Bogeyguy's profile
Bogeyguy
548 posts in 2069 days
#15 posted 02-13-2013 01:11 PM
What’s wrong with dain bramage??
-- Art, Pittsburgh.
