Will the cold affect digital displays?
Forum topic by JesseTutt posted 02-12-2013 04:12 PM 856 views 0 times favorited 3 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2080 days
02-12-2013 04:12 PM
Topic tags/keywords: measuring tools lcd temperature
Years ago, in far far away Michigan, I left my calculator (HP 41c), that had a LCD display, out in the car overnight during the winter. Evidently the LCD froze and cracked something and it was expensive to get it repaired. I believe that I was told that there were actually thin glass sheets holding the liquid crystal material in place.
Jumping forward to today; will the current generation of LCD displays in digital calipers, angle measurers, height displays, etc. be damaged or destroyed by cold temperatures? I always forget to gather up the correct digital tool when I go out to the shop and end up having to make (sometimes multiple) trips to get what I need from the house. Besides, I always take the battery out and put it next to the device (this saves the battery). Unfortunately, a small, light weight shiny object attracts cats.
I Missouri the unheated shop rarely gets below 0 degrees in the winter.
I guess the opposite question also should be asked. Will 100+ degree August temperatures damage the tools?
3 replies so far
View Mosquito's profile
Mosquito
9280 posts in 2262 days
#1 posted 02-12-2013 04:19 PM
It would depend on the type of digital display in question. A VFD display will function fine in the cold, but LCDs will still have issues in the cold.
100 degree days shouldn’t really be much of an issue for either
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View MonteCristo's profile
MonteCristo
2099 posts in 2158 days
#2 posted 02-12-2013 06:31 PM
I think the relative humidity swings that occur with temperature changes are as big an issue as the actual temperature change itself.
View Marcus's profile
Marcus
1163 posts in 1989 days
#3 posted 02-12-2013 06:35 PM
Interesting question, and the answer is probably maybe. I’ve left my laptop outside on a -20 degree day with no damage. I have a 7” LCD inside my truck that is constantly outside with no issues. These are a bit higher end display devices than what you might find in a cheaper pair of calipers (I think I bought a set for $10), so maybe their could be issues there. Im tempted to toss mine outside just to see.
