Tape measure graduated in tenth's of an inch
Forum topic by MrRon posted 101 days ago 993 views 0 times favorited 34 replies Add to Favorites Watch
View MrRon's profile
MrRon
1575 posts in 1414 days
101 days ago
Topic tags/keywords: question
What is this used for?
34 replies so far
View MaroonGoon's profile
MaroonGoon
94 posts in 129 days
#1 posted 101 days ago
Used for engineering units I think. Someone correct me if I’m wrong. Working for my dad who is a land surveyor, we took measurements in tenths which is then translated onto the maps and drawings.
edit* our tape measures and rulers were marked at every tenth of an inch so we would read the measurement out loud as 1.4 feet
-- "Only put off until tomorrow what you are willing to die having left undone." -- Pablo Picasso
View Rick M.'s profile
Rick M.
1497 posts in 551 days
#2 posted 101 days ago
They’re awesome and once you get used to it, 8ths never makes sense again.
-- -- Rick M.
View FirehouseWoodworking's profile
568 posts in 1444 days
#3 posted 101 days ago
MaroonGoon, you are correct. You may also find them in the machinist trade, but mostly in the surveying trade.
Rick, kinda like mixing metric and SAE!
Cheers!
-- Dave; Lansing, Kansas
View CessnaPilotBarry's profile
CessnaPilotBarry
602 posts in 281 days
#4 posted 101 days ago
I often saw used measuring tools graduated in 10ths and 50ths that once were used in the Pratt and Whitney aircraft engine factory.
Starrett still sells then new.
-- It's all good, if it's wood...
View Grandpa's profile
Grandpa
2381 posts in 846 days
#5 posted 101 days ago
They are used in the drafting of engineering drawings….in the pencil and paper days. They are great and make a lot of sense when you are converting everything to decimal fractions.
View Nighthawk's profile
Nighthawk
423 posts in 528 days
#6 posted 101 days ago
sounds like some one wants to use the metric system … lol
-- Rome wasn't built in a day... but I wasn't on that job? ... http://www.southernrider.co.nz/projects/
View Loren's profile
4893 posts in 1819 days
#7 posted 101 days ago
A dial caliper is graduated in 10ths.
I use both imperial and metric calipers a lot.
View bondogaposis's profile
bondogaposis
1254 posts in 522 days
#8 posted 101 days ago
Engineers scale, they are great because everything is automatically in decimals and eliminates fractions. Unfortunately no one uses them and therefore all plans and lumber sizes etc are all geared to fractions of an inch instead of tenths of an inch.
-- Bondo Gaposis
View Lee Barker's profile
Lee Barker
1889 posts in 1021 days
#9 posted 101 days ago
I have a rule in tenths at my desk and it gets used in this way: Scaling dimensions off a picture. Sometimes a few dimensions may be given. Sometimes you can infer a dimension, say the height of a table or desk. From that you can get all the other dimensions you want using ratios. If I had to do it in fractions, it would take nearly as long as doing it in roman numerals.
Kindly,
TopamaxSurvivor
13194 posts in 1847 days
#10 posted 101 days ago
sounds like some one wants to use the metric system … lol Metric would be good if it had an inch. decimeter is too big and centimeter too small ;-(
Grandpa
#11 posted 101 days ago
Decimal fractions are so much easier to woirk with. I was on a job a few years back. the welder showed up to do some measuring for his part. We were making a grooming room for a vet. There were to be 6 kennels on each side and he wanted to make sure of what he was building so it would fit the space. Unfortunately he had left his calculator that works fractions. I told him to give me the dimensions he was getting on his tape measure. He read them off and I wrote them on a board in decimals and added them up. I did my division or whatever we needed. He didn’t trust me but he left with my board and it WAS correct. Decimals are really easy to work and the scale is callibrated for reading them.
TopamaxSurvivor
#12 posted 101 days ago
Actually most tapes have decimals, but .125, .0625, ect aren’t quite as convenient as .1,, .2, ect. But it will keep you mentally sharp(er) ;-))
Grandpa
#13 posted 101 days ago
That is what I do most of the time Topa. I convert all the 1/16th’s to decimals to work with them. I memorized them 35 years ago by using them. part of my job.
TopamaxSurvivor
#14 posted 101 days ago
You will be sharper if you forget them and recalculate every time you need one ! ;-))
Grandpa
#15 posted 101 days ago
I cn calculate them but since I know I just jot it down. I add , subtract or whatever and then covert them back to common fractions. They have to convert if you have used 1/16th’s or 1/32nd’s. I know all the decimal fractions to an inch. Just learned thm over the course of a short time back there. I used them daily and remembered them. Hard to forget them. If I do forget them I might not be sharp enough to do the math anymore….LOL
showing 1 through 15 of 34 replies
