delta BS and DeWally RAS
Forum topic by Madwood posted 02-11-2013 06:56 PM 757 views 0 times favorited 0 replies Add to Favorites Watch
View Madwood's profile
Madwood
68 posts in 2959 days
02-11-2013 06:56 PM
I am moving at the end of the month and can’t take these with me, so they gotta go.
Rockwell/Delta 28-200 is a 1970 build. I bought it used and was from a local high school shop that closed the wwking program. It has, I believe, a 1/2HP motor maybe 3/4, I can’t read the plate. Also has a riser block and takes 105” blades. Original Delta fence and can lamp. It does run well, but needs a new lower wheel pulley and a little TLC. I have a couple blades for it that are used but still pretty sharp. Asking $300 or reasonable offer.
B&D/Dewalt 1150 RAS. It’s an 8” blade. Not really alot to say about it, smaller saw but works well. Everything is tight and works the way it should. I did have to replace the switch with a toggle, original was bad when I got it. $100 or reasonable offer.
No shipping, so best left to the guys in central NY. Located in Canastota, NY, off Exit 34 of the Thruway.
Sorry I have no pix, but if you’re interested, you can come and take a look and I’m sure we can come to some sort of agreement. PM me if you wanna see.
Thanks, John
-- In the shop making chaos out of order
0 replies so far
