Table saw blade size
Forum topic by 12strings posted 02-11-2013 04:21 PM 1757 views 0 times favorited 24 replies Add to Favorites Watch
View 12strings's profile
12strings
434 posts in 2348 days
02-11-2013 04:21 PM
My fairly cheap table saw has a 10” blade in it. But I went over to my friend’s house and he had a really old huge cabinet saw with what looked like a 7” blade.
Is there any advantage to using a smaller blade on a table saw?
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
24 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3613 days
#1 posted 02-11-2013 04:26 PM
blade cost would be 1 advantage.
a disadvantage would be:
1. depth of cut
2. quality of cut (to some degree, and more noticeable on some cuts than others), as the moving speed of the cutting teeth is lower than on a 10” blade
I suppose if you have specific cuts that require a specific blade geometry (flat ground teeth for example) and you need to make shallow cuts and don’t want to invest in a full 10” blade, that would be a valid option.
If you have blades from your circular saw that you want to use in your TS – that would be an option.
Other than that, I see no reason to use 7” blades in a 10” capable saw
View b2rtch's profile
b2rtch
4851 posts in 3012 days
#2 posted 02-11-2013 04:30 PM
7” are not as common and probably more difficult to find and with less variety
-- Bert
PurpLev
#3 posted 02-11-2013 04:35 PM
Bert – 7 1/4 blades are very common – available in all hardware stores for circular saws. come in a variety of configuration (ripping/combo/cross cut/laminates/matal/etc)
View 1stmistake's profile
1stmistake
13 posts in 2135 days
#4 posted 02-11-2013 04:45 PM
Matthias has a short bit about using skilsaw blades in a table saw:
http://woodgears.ca/shop-tricks/skillsaw_blade.html
10254 posts in 3612 days
#5 posted 02-11-2013 05:28 PM
You may have seen a dado blade on the saw.
12strings
#6 posted 02-11-2013 08:17 PM
Thanks for the replies, woodgears is always an interesting read…
...It was definitely one blade…We used it to rip down some stock.
View crank49's profile
crank49
4030 posts in 2935 days
#7 posted 02-11-2013 08:57 PM
My dad had an ancient old Craftsman TS that was a 9” saw with a 3/4 hp motor.
It was a decent saw but with limited power it actually worked better with a 7 1/4” blade.
That old saw had a 4” jointer attachment on the side of it that used the same motor.
View knotscott's profile
knotscott
7980 posts in 3340 days
#8 posted 02-11-2013 09:07 PM
My biggest concern with using a 7-1/4” blade is that the kerf width is far more likely to be narrower than the splitter or riving knife, which would cause binding of the workpiece in the middle of the cut. The smaller diameter also changes the effective hook angle of the blade, which can increase tear out on crosscuts and ply.
View Grandpa's profile
Grandpa
3259 posts in 2640 days
#9 posted 02-11-2013 09:52 PM
Knot, in the post he said it was a REALLY OLD cabinet saw. Do you suppost it even had a splitter let alone a riving knife??
View Clint Searl's profile
Clint Searl
1533 posts in 2325 days
#10 posted 02-11-2013 09:54 PM
I used nothing but Forrest, Ridge, and custom Cermet 10” blades since the ‘80s until I switched to a Freud Fusion 8” combo a couple years ago. The only reason I’d go back to a 10” would be to rip stock that the 8” can’t handle. The Freud is a joy to use.
knotscott
#11 posted 02-11-2013 09:58 PM
”Knot, in the post he said it was a REALLY OLD cabinet saw. Do you suppost it even had a splitter let alone a riving knife??”
Probably not, but I made that statement to prevent a bunch of folks from putting a 7-1/4” blade on their saws, and thinking there isn’t any downside.
View unisaw2's profile
unisaw2
209 posts in 2999 days
#12 posted 02-11-2013 10:58 PM
For thin wood for inlay I use a 6-1/2” blade in my full size table saw. The kerf is 1/16” (vs 1/8” on a 10” Forrest blade). I use it with a zero clearance insert, a nail for a splitter, and a shoe type push stick. Works great on small thin wood (like ripping 1/8” thick material). Since the kerf is smaller, less wood is wasted, and it is runs a lot quieter. YMMV
-- JJ - Northern Illinois
View cutworm's profile
cutworm
1075 posts in 2757 days
#13 posted 02-11-2013 11:59 PM
I was thinking that the arbors were different in size but I guess that they aren’t.
-- Steve - "Never Give Up"
12strings
#14 posted 02-12-2013 03:03 AM
FYI, the “really old saw” had not splitter, riving knife, or blade guard…just a blade sticking out of a big cast iron table.
After this thread, I may go out and get a smaller blade for my saw…its just a cheap craftsman bench-top saw…and I really think the slower speed and thinner blade would allow me to not stress the engine as much. I’m not going to be re-sawing 3 inch stock on this thing anyway. Thanks for all the input.
Grandpa
#15 posted 02-12-2013 03:24 AM
Fair enough. I wasn’t jumpinmg on you. I just thought riving knives and even splitters were items from the last 40 years. I guess some of these guys think that is ancient but there are some really old tools out there. Good point though. The smaller blade and the splitters/riving knives probably won’t go together.
