Why does my resawn 1/8" veneer cup when glued?
Forum topic by DustyJohn posted 02-11-2013 03:12 PM 1750 views 0 times favorited 11 replies Add to Favorites Watch
View DustyJohn's profile
DustyJohn
19 posts in 2177 days
02-11-2013 03:12 PM
I resawed some solid oak to 1/8” to use as veneer. As I glued it to my project, it cupped as it dried. Has anyone run into this before? What am I doing wrong. I must admit, I do not spread the glue evenly, just put beads down and wiggle it when applied to spread it.
11 replies so far
View bondogaposis's profile
bondogaposis
5155 posts in 2592 days
#1 posted 02-11-2013 03:25 PM
What are you gluing it to?
-- Bondo Gaposis
DustyJohn
#2 posted 02-11-2013 03:37 PM
I had 4.5” pine door jambs in a closet. I sanded them before I applied the oak veneer.
View SamuraiSaw's profile
SamuraiSaw
515 posts in 2205 days
#3 posted 02-11-2013 03:38 PM
What kind of glue are you using?
Open grain woods like oak do not like moisture and will react to it. You also need to spead the glue completely and evenly, then apply pressure across the entire area until the glue dries.
-- Artisan Woodworks of Texas.... www.awwtx.com
bondogaposis
#4 posted 02-11-2013 03:53 PM
That is kind of an odd project, I’m not sure if what you are trying to do is even possible. Is the door jamb in place? The veneer cups because of the moisture in the glue causes the wood to expand on the glue side. You need to be able clamp the entire surface tightly while the glue cures. Contact cement might work for this type of glue up, then you won’t need to clamp it. You’ll need to roll it.
-- Bondo Gaposis
DustyJohn
#5 posted 02-11-2013 03:54 PM
I use elmers glue, I have to save up just to be poor….
SamuraiSaw
#6 posted 02-11-2013 04:20 PM
Bondo is spot on. There’s nothing wrong with Elmer’s per se, but it isn’t the glue of choice for this application. The moisture in the glue is working against you. Contact cement is your best option.
View Loren's profile
10477 posts in 3889 days
#7 posted 02-11-2013 04:46 PM
Some little nails will hold it down as the glue dries. You can
pull them out later.
404 - Not Found
2544 posts in 3210 days
#8 posted 02-12-2013 01:05 AM
Wet the front with a damp cloth to even out the moisture as well. It will buckle if no pressure is applied. As it’s in a door jamb, you could use some pieces cut slightly wider than the opening and wedge across the opening to keep it in place while it dries.
DustyJohn
#9 posted 02-12-2013 04:53 PM
Thank you everyone for the wisdom. I’m going to try all your advice.
View crank49's profile
crank49
4032 posts in 3212 days
#10 posted 02-12-2013 06:10 PM
Well, don’t try all the advice at the same time.
Wetting the front also, for instance, will NOT be a good idea if you use contact cement
Also, if you use contact cement be sure to use it according to the directions.
ESPECIALLY the part about letting the glue surfaces almost dry before putting them together.
I’ve seen many jobs fail in the shop because someone got in a hurry and stuck wet contact glue surfaces together. This will not work.
View MrRon's profile
MrRon
5277 posts in 3484 days
#11 posted 02-12-2013 08:44 PM
I think your main problem is: The veneer is too thick. I wouldn’t use any veneer thicker than 1/32”. The thinner it is, the easier it is for the veneer to lay flat. Thick veneer has too much “spring” to it, unless you can provide good overall clamping pressure.
