Problems with 2/0 blades
« back to Scrollsawing forum
Forum topic by americancanuck posted 02-11-2013 10:48 AM 1123 views 0 times favorited 5 replies Add to Favorites Watch
View americancanuck's profile
americancanuck
416 posts in 2694 days
02-11-2013 10:48 AM
Topic tags/keywords: question
I notice that a lot of scrollers whose work I admire use, and recomend, a 2/0 blade for intricate fret work. My sucess level with this blade is terribable. I have been trying to use FD-SR 2/0 blades on my DW-788 with no sucess at all. I just don’t seem to be able to control the blade. It’s like it has a mind of its’ own and sends the wood where it wants it to go instead of where I try to point it. I am haveing good luck, for a rank beginer, with a #1 blade and my projects are coming out well but I can see times when the smaller blade would be a real advantage. Any advice on how to accomplish this would be appreciated.
-- Retired and lovin it
5 replies so far
View Sheila Landry (scrollgirl)'s profile
9237 posts in 3004 days
#1 posted 02-11-2013 11:07 AM
I hate to say, but I had the same problem with the FD blades. I know people love them, but both Keith and I tried them more than once on a variety of types and thicknesses of wood and we had no control of them. They seemed to turn as an “afterthought” when you tried to turn them and as you said, they wandered and followed wherever they seemed to feel like wandering.
At first we thought it was the tension on our saw. We tried to keep it tighter and still the same results. I just think it is the nature of the blade and that some people have learned how to compensate for them.
We use Olson blades pretty pretty much exclusively. My favorites are the 2/0, 2 and 5 regular reverse (although the PGT reverse tooth are nice) We also love the Mach Speed reverse-tooth blades in size 3, which do an amazing job and last a long time. If the Mach blades came smaller, we would probably use them too, but the 3 is the smallest that they make them.
These four blade sizes accomplish about 95% of the cutting we do. Sometimes we may use a slightly larger blade for particularly thick wood, or when we need longer straight lines, but for the most part, these do the job.
I would suggest you try the Olson’s. (NO – I do NOT get compensated for recommending them) I just don’t think I would be able to cut the same with any other blade.
I have a blade chart from them if you would like. PM me your email and I will send it to you. They are available from The Wooden Teddy Bear online.
Let us know what you decide. :)
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View StayinBroke's profile
StayinBroke
53 posts in 2055 days
#2 posted 02-18-2013 03:43 AM
I personally haven’t tried the FD blades, but I can second what Sheila said about the Olsen blades. They’re all I use, and have not had a problem with them yet. Good quality and won’t break the bank.
-- I'm just me.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3565 days
#3 posted 02-18-2013 04:09 AM
I’m not a scroll saw expert by any means, but like Sheila said, I have had great luck with the Olson 2/0 blade.
-- Wayne - Plymouth MN
View William's profile
William
9950 posts in 2927 days
#4 posted 02-25-2013 01:34 PM
I love Flying Dutchman blade. For anything above size #3, that’s all I use.
When you start messing with anything smaller though, I recommend Olson.
View JesseTutt's profile
JesseTutt
854 posts in 2195 days
#5 posted 02-25-2013 02:11 PM
+1 on the Olson
