"Stripped" pocket hole screws
Forum topic by jstewart posted 439 days ago 940 views 0 times favorited 10 replies Add to Favorites Watch
View jstewart's profile
jstewart
141 posts in 988 days
439 days ago
Topic tags/keywords: pocket hole joinery strength
On my current project, I’m using a lot of pocket hole joinery. After drilling the pocket holes, I did a dry fit (no glue) to see what everything would be like when finished. (It was almost perfectly square, which made me very happy.) One problem I ran into was over-tightening the pocket hole screws. I seem to have “stripped” a couple of them. By “stripped” I mean I tightened to the point that the screw just spun in the hole, as if I had destroyed the threads made by the self-tapping screws. This only happened at one joint, where I was able to add a third pocket hole without any problems. Should I be very concerned. That joint now has 3 pocket screws, two of which are “stripped”. After doing the glue-up, should I still feel confident in the holding power of the joint?
-- Joshua, Olathe, Kansas
View ChicoWoodnut's profile
ChicoWoodnut
895 posts in 712 days
439 days ago
What kind of material is it? Particle board? Wood? Ply?
View cmaeda's profile
cmaeda
192 posts in 451 days
439 days ago
I had a similar problem. Try driving the screws in by hand. Its’ easy to use too much force when using a drill for this.
If the joint is critical and will be under stress, you could make a loose mortise and tenon to strengthen the joint.
View jdashburn's profile
jdashburn
4 posts in 440 days
439 days ago
Yes, I would be concerned about the holding power. Cut a piece of wood the same diameter as the hole and glue it in. You may need to clean out the hole a little more first. Wait for the glue to dry then re-drill the hole and put in the screw. One great thing about this type of joinery is that only you know the location of the mistake.
View gusthehonky's profile
gusthehonky
131 posts in 639 days
439 days ago
I use golf tees to repair door jams when damaged or oversized holes exceed the size hinge screws need. Add glue and trim to size.
-- Ciao, gth.
View mleedix's profile
mleedix
54 posts in 447 days
438 days ago
If there is room and the joint is absolutely hidden. You can drill out the hole insert and glue a hardwood dowel. Let that set up overnight, sand it smooth and then redrill your pocket hole.
-- - Michael [..for God's glory." 2 Cor. 10:31] Over 300000 species of trees, yet we take the credit for their beauty...
View CedarFreakCarl's profile
CedarFreakCarl
566 posts in 950 days
438 days ago
Looks like you’ve got plenty of good advice for fixing the stripped out holes. One thing to watch is to use the right screws for the the right wood which may or may not be the problem in your case. Fine threads for hard wood and coarse threads for pine, cypress etc. You probably already know it, but I thought I’d throw it out there just in case. Screw length is important too depending on what board thickness you have. Your pocket screw manual can help you there. One more thing, I’ve fixed stripped out holes just by putting 5 min epoxy in, letting it set up and then re-screwing. Good luck.
-- Carl Rast, Pelion, SC
View CessnaPilotBarry's profile
CessnaPilotBarry
1285 posts in 599 days
438 days ago
You can also harden the threaded area of the wood with CA instant glue.
You want the thin stuff, so it soaks in.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
jstewart
438 days ago
Thanks for all the great ideas on how to fix this. I took a step back from the project to think about this issue before continuing on with anything. I think I’ve actually come to the decision to not do anything about it. The joint has 3 pocket screws, one of which is nice and tight. I tried to pry it apart with my hands and couldn’t even get it to show a gap (and that’s with no glue on the joint yet). Also, after thinking more about where this joint will be in the end product, I realized that it really needs to hold up to shearing strain, not forces trying to pull the joint apart. Also, in the end, there will be a plywood shelf briding this joint. I plan to put pocket holes from the shelf into both the stile and rail. This will also add more strength to the joint. And to go with all of that, since this stil and rail will actually be on the floor, forming a frame-and-flat-panel side to a carcase, I plan to back up this corner with a hidden 1-1/2” X 1-1/2” block, to give the corner a bit more size and strength. With all of these reinforcements in play, I think I’ll take my chances with this joint as is.
Don’t get me wrong. I greatly appreciate all of the advice and ideas. In fact, since I haven’t glued anything up yet, I’ll probably go with the CA glue idea, the day before I decide to drive the screws one final time. I’ll also be careful to use my lower-powered cordless drill with a low torque setting when setting screws for now on.
View Safetyboy's profile
Safetyboy
87 posts in 656 days
437 days ago
I think you’ll be all right, as long as you’ve got some glue in there:
We needed an “emergency baby gate” after we brought home our 2nd adopted son at 1-1/2 years, who wasn’t used to stairs… so I grabbed some left-over poplar and pocket screwed the whole thing together in an hour or two.
Now that he’s been with us for a few months & manages stairs okay, we don’t need the gate anymore, so last week I took it down. Took it out to the garage and thought – “hey, I can take out those pocket screws and re-use them on something else!” So I did.
When I made the gate, I put a dab of glue on each joint… and with the screws removed, the left-over glue is still strong enough on that simple butt-joint that I can stand on the rungs no problem!
-- -- Kevin in Mentor, Ohio
View Don Niermann  's profile
Don Niermann
155 posts in 869 days
437 days ago
Put some tooth picks iin the screw holes and screw them. Do not need any glue.
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
