Arts & Craft Mantle
Forum topic by dave105 posted 02-11-2013 01:25 AM 1122 views 0 times favorited 3 replies Add to Favorites Watch
View dave105's profile
dave105
29 posts in 2249 days
02-11-2013 01:25 AM
Topic tags/keywords: mantle arts craft walnut dental molding
This mantle was made for our daughter’s new house. It is solid walnut. The dental molding was cut on the table saw. I used the same system you would use to cut box joints.
3 replies so far
View AandCstyle's profile
AandCstyle
2979 posts in 2166 days
#1 posted 02-11-2013 03:57 AM
It looks great. Please post some pix once you get it hung. Speaking of which, how much does it weigh and how do you intend to mount it to the wall?
-- Art
dave105
#2 posted 02-11-2013 09:31 AM
Art, Notice the two pieces of 1 inch thick oak protruding from the bottom of the mantle on each side. Those are swivel pieces that are attached at a swivel point on the back. The pieces extend on the top of the mantle as well. The builder placed two 3/8 all thread rod on the place where the mantle was to be hung.. I drilled two over sized holes on the back of the mantle. Then I filled the holes with caulking.With my son-in laws help we placed the mantle on the all thread rods. I screwed the extended pieces to the wall. On both top and bottom.After the caulking set up I removed the screws. then I tapped the extended pieces around out of the way. The reason for the 1 inch thickness is that the fireplace will be covered with stone.
As for weight. I did not actually weight but both of us together had no trouble lifting it.
AandCstyle
#3 posted 02-12-2013 01:56 AM
Ah, that should do the trick. It is good to plan a head! ;)
-- Art
