« back to Hand Tools forum
02-10-2013 05:22 PM
I have a new set of Stanley sweetheart chisels that have been patiently waiting for me in a drawer of my work table.
My night time reading has been Leonard Lee’s Complete Guide to Sharpening, I have an angle jig and guide at the ready, today may be the day…..
My question is this: how exactly do you get lacquer off the chisels? Please…... talk…... very…... slowly…... I’ve read about solvent and acetone. Only thing I know about acetone is that I think that’s what’s in nail polish remover. Would Varsol work?? If not, what would you recommend, and a brand name would be appreciated.
Thanks Sandra
Update – From the mom-files!
I found a bottle of drug-store brand nail polish remover under the sink. First ingredient was acetone. So I poured some into a glass pie plate, propped up one end slightly to make a bath for the chisels without getting the acetone in the handle area.
I let them soak for about an hour and then scrubbed them down with an SOS pad. Not sure what they’d be in the US, but they are steel-wool type scouring pads for the kitchen that are pre-soaked with detergent.
It took a bit of elbow grease and a few drops of blood (who knew they’d be that sharp already…..) but they are done.
Thanks for the help. I had read the blogs also, and was going to head in tomorrow to HD to find the ‘blue can’ stuff.
Cheers, Sandra
-- No, I don't want to buy the pink hammer.
22 replies so far
#1 posted 02-10-2013 05:24 PM
Any lacquer thinner should take it off.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
#2 posted 02-10-2013 05:31 PM
Any hardware store should have acetone also
-- Mother Nature created it, I just assemble it.
#3 posted 02-10-2013 05:41 PM
yep! follow directions. Be sure the space is WELL VENTILLATED. air out the rags. Don’t be like me, be patient. LOL!
-- Cau Haus Designs, Thomas J. Tieffenbacher
#4 posted 02-10-2013 05:42 PM
you can get lacquer thinner at the home improvement/hardware/woodworking store.
curious though – where (and why) do you have lacquer on your chisels that you need to remove it?
#5 posted 02-10-2013 05:44 PM
Whatever Stanley puts on those things, it’s TOUGH! I don’t think it’s lacquer, but some sort of urethane.
Lacquer thinner or acetone didn’t strip mine, I ended up removing the handles and soaking them in a stripper formulated to break urethane.
By comparison, my Two Cherries and Pfiel tools had a coating that wiped right off with lacquer thinner.
#6 posted 02-10-2013 06:49 PM
Sorry for being obtuse but Varsol, which I have on hand, is a paint thinner. Is that the same as lacquer thinner? If I hadn’t read posts on the Stanley chisels, I never would have known that I’m supposed to strip them. I don’t recall anything in the packaging, but it has been awhile.
S
#7 posted 02-10-2013 07:46 PM
No Paint thinner is not the same as lacquer thing lacquer thinner is much stronger and more effective at removing lacquer finishes because it’s the solvent used to mix Lacquer in .
#8 posted 02-10-2013 07:58 PM
A paint thinner is a solvent used to thin oil-based paints or clean up after their use. Commercially, solvents labeled “Paint Thinner” are usually mineral spirits good for cleaning many plastics and vinyls
Lacquer Thinner is usually a mixture of solvents able to dissolve a number of different resins or plastics used in modern Lacquer. softens and can remove many plastics and vinyls
Shellac is a lacquer with an alcohol as solvent.
here is general discussion on solvents
#9 posted 02-10-2013 08:50 PM
Sandra, Sorry to hear of your trials and tribulatiions, I Googled “Stanley Chisel Coating” And got quite a BLOG on the difficulty you are also having. Only one person came up with an answer that said it came right off and that was “The Blue Can ” acetone (Straight maybe 100%) from HD Lowe’s probably has the equivalent of pure acetone. Other mixed solvents and laquer thinners MEK and such didn’t touch it. One guy soaked his several days in laquer thinner then scraped most off with a razor blade.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
#10 posted 02-10-2013 08:53 PM
I had the same issue with Marples chisels. Soaking for an hour or so in lacquer thinner softened it enough to scrape it off.
-- Artisan Woodworks of Texas.... www.awwtx.com
#11 posted 02-10-2013 08:56 PM
Anyone email stanley and ask what the coating is and what removes it ?
-- ... Never Apologise For Being Right ...
#12 posted 02-10-2013 09:00 PM
Yep, you can get a can of acetone in the paint department at Lowes. Acetone is a very strong solvent that will attack most plastics, so be careful where you use it. Remove the handles before you try to clean your chisels or you will be left with bare wood. Acetone is relatively non-toxic, but use it in a well ventilated area and away from any ignition sources. Wear good rubber gloves. You can let any rags air dry or rinse them with water (water and acetone are miscible).
#13 posted 02-10-2013 09:44 PM
Feeling quite pleased with the outcome. Can I name it the Sandra method? Or how about the witchin’ kitchin’ method???
#14 posted 02-10-2013 09:55 PM
Should I be pleased that the lacquer coating doesn’t bother me, or should I be wanting to strip my SW #750s? I figure ‘no harm, no foul…’
Sandra, I am glad you found a solution! Enjoy the chisels, I love ‘em!
#15 posted 02-10-2013 10:24 PM
If the coating is left in place, it clogs stones when the backs are flattened.
I go it off my set with a stripper that removes urethanes, no scrubbing required. It is certainly tough stuff!
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12033 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2108 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
431 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
340 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1370 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
4907 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
6696 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
28069 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
212 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5413 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1420 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6233 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1388 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2154 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1187 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
4759 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2201 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
8847 |
