Forum topic by ScrubPlane | posted 02-10-2013 04:27 PM | 1577 views | 0 times favorited | 12 replies | ![]() |
Topic tags/keywords: lathe turning tip I have now figured out the ‘mystery’ of mounting a piece in my SuperNova chuck such that it stays (the instructions didn’t say anything regarding length). What the instructions do say, however, is to turn at relatively low speeds while I see the turners on TV turning at higher speeds. What say yee…what speeds do you turn your blocks while using a chuck? THANKS… |
12 replies so far
#1 posted 02-10-2013 04:41 PM |
Sounds like a goofy answer, but my turning speeds are relative to the size of the workpiece. -- bill@magraphics.us |
#2 posted 02-10-2013 05:17 PM |
You do not mention using tailstock support obviously longer lengths/widths need extra support. Not aware of a rule of thumb as far as length/width to use or not use tailstock support or lathe speed. I use tailstock support until it gets in the way whether spindle or bowl turning. Lathe speed depends upon what am turning, more than size. Boils down to common sense, confidence, and experience. -- Bill |
#3 posted 02-14-2013 07:32 PM |
I’ve seen this formula posted in several places. Diameter x speed = 8000 to 9000 Take the diameter and divide into 8000 to 9000 = speed I usually divide into both 8000 and 9000 to get upper and lower speed. I don’t usually follow this on small turnings but do with larger things like large bowls. -- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - - |
#4 posted 02-14-2013 11:02 PM |
In addition to the other advice… turn as fast as you feel safe. A faster speed often means a shorter completion time and a cleaner cut, but also more of a chance for something to go wrong. I start roughing pieces really slow. Once I’m sure they are balanced, I turn it up. If at any point I start to feel uncomfortable with the wood or the cut, I slow it down again. Also, since no one else mentioned, turn the speed down low when you are sanding. High speeds generate heat, which can crack or burnish the wood, and also can cause the adhesive on the sandpaper to weaken, shortening its life. -John |
#5 posted 02-16-2013 01:51 AM |
My understanding is that you turn the speed up to sand, otherwise it takes forever. If you don’t press too hard, heat build up can be avoided. When turning pieces that are out of round or out of balance, I start at low RPMs and turn up the electronic speed dial until I get some vibration, then back off a bit. This is where electronic variable speed really shines. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#6 posted 02-16-2013 02:27 AM |
+1 for Bill White. -1 for speeding up to sand cuz it’s faster. -- I dream of a world where a duck can cross the road and no one asks why. |
#7 posted 02-16-2013 02:46 AM |
I have a delta 46-460 with variable speed. I have the belt set on the medium pulley and I haven’t needed to change it for anything. I’ve noticed that sometimes turning the speed up negatively affects the cutting, plus there is more risk of accident. -- A positive attitude will take you much further than positive thinking ever will. |
#8 posted 02-16-2013 03:14 AM |
Turn fast, sand slow. The formula Dewayne provided is a common, and good one. The other rule of thumb is “turn it up until it gets scary, then turn it down a bit”. Obviously this one is not without its hazards, but is also common and used at your own risk and based on comfort level and experience, use of the tail stock, etc. As far as your tenon, make sure it has the correct taper for the jaws, and does not bottom out. -- Robert --- making toothpicks one 3x3x12 blank at a time! |
#9 posted 02-16-2013 03:43 AM |
When starting your lathe, just make sure you are NOT standing in front of the workpiece. Stand off to the side so if the wood comes undone and comes off the lathe, it won’t hit you. It may take out a window or something but not you head or eye. Emergency rooms and mortuarys are not fun places to visit. Be safe and have fun. -- Gary |
#10 posted 02-16-2013 03:41 PM |
Thank you for all for your thoughts and suggestions. My NOVA chuck’s instructions suggest no higher than 600 rpm which just didn’t seem right relative to what I’ve seen on TV or YouTube. After having experimented on my own and from discussions like this, I’ve come to the belief that those manufacturer numbers are for their own liability more than anything. THANKS… |
#11 posted 02-16-2013 05:44 PM |
Were they talking about the cole jaws? 600 rpm is the recommended max RPM on those, and I would follow that. But for standard use of the chuck and jaws that is really slow for a max speed. I may have to dig out my manuals now! (granted my experience is with the G3 and the Super NOVA 2, so some of the others may have different instructions) -- Robert --- making toothpicks one 3x3x12 blank at a time! |
#12 posted 02-16-2013 10:53 PM |
Robert spot on concerning cole jaws. I say save your money and just use a jam or donut chuck for reverse turning bowl bottoms. I scanned the manual and think it is well written with sage advice for someone with experience or just starting out. Other than how to install threaded insert & jaws or cleaning not sure what manual has to say for my Oneway chucks. CAPACITY: DO NOT USE THE SCREW FOR VERY LARGE WOOD BLANKS. Its use is intended for small bowl and screw chucking work. The maximum capacity which should be mounted on the screw – 250mm (10 inches) diameter x 100mm (4 inches). DO NOT EXCEED 600 RPM FOR THIS OPERATION. Use tailstock support. DOVETAIL OPERATION They should have omitted RPM’s and mentioned tailstock support what most folks do any way. -- Bill |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6696 |
28067 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4758 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8846 |
