would this work?
Forum topic by SCOTSMAN posted 02-09-2013 08:11 PM 862 views 0 times favorited 6 replies Add to Favorites Watch
View SCOTSMAN's profile
5849 posts in 3521 days
02-09-2013 08:11 PM
I bought one of these to convert into a dust extractor. It is very very powerful so no probs there .What do you think ? Mine is a different model from this but big heavy and did I say powerful LOL .what do you guys and ladies think? Alistair
View Dallas's profile
3599 posts in 2423 days
#1 posted 02-09-2013 08:17 PM
540 CFM isn’t all that much, I wonder how much power the motor is rated for and the size/material of the impeller.
The impellar material is important. If a stray chunk of wood hits it you do not want it coming unglued and taking the rest of the blades with it.
I have a cheap Harbor Freight 1 HP unit I got here in the states that was rated 660CFM and 1 HP on a condenser motor.
I am reworking it to make it much more efficient.
View jim65's profile
995 posts in 1869 days
#2 posted 02-09-2013 08:22 PM
I would connect your hose to a bucket first then to the fan – like the attachements used to vacuum out fireplace ash – these collect the “solids” first in the bucket and the dust would go to a bag. running a small block of wood through it may be an issue for the fan blades. looks good!
-- Jim, Marostica Italy
View MrRon's profile
4676 posts in 3179 days
#3 posted 02-09-2013 08:51 PM
No. A fume extractor is not the same as a dust extractor. It looks like that unit has high velocity, but low capacity. Sawdust extractors need high capacity and high velocity.
18227 posts in 3612 days
#4 posted 02-09-2013 09:58 PM
I doubt it too. Might help with very fine dust in the air, but that is about it. Should do a good job of positively ventilating the work station to keep you dust free ;-)
View SteveL's profile
167 posts in 3704 days
#5 posted 02-09-2013 10:02 PM
I agree with MrRon. This would be good ventilation if you were making a spray booth, but it probably would not be good for a “whole-shop” dust extractor. If you do use it, you should definitely have a pre-stage like the one from Oneida—also I think that 455 pounds sterling is a bit pricy for 540 CFM, as Dallas says.
-- SteveL
View Joe Lyddon's profile
Joe Lyddon
10012 posts in 3988 days
#6 posted 02-09-2013 10:53 PM
Dog gone it… it sure looks good though… pretty blue n all…
How about a shop made air filter?
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
