Dewalt DW788 scrollsaw
Forum topic by rayn posted 02-09-2013 07:11 PM 1960 views 0 times favorited 5 replies Add to Favorites Watch
View rayn's profile
rayn
176 posts in 3459 days
02-09-2013 07:11 PM
Topic tags/keywords: question
I went to turn on my Dewalt scrollsaw and nothing happened and I don’t remember any problems in the past when I trurned it off. I checked the fuse and the switch with a VOM and they appear OK Any suggestions?
Ray
-- Ray,Iowa
5 replies so far
View Kazooman's profile
Kazooman
1270 posts in 2193 days
#1 posted 02-09-2013 07:16 PM
Are you certain that the switch is OK? I had the switch on my Delta table saw break when I turned it off. It broke in the ON position and left the blade spinning. Clearly a safety hazard.
Is there a breaker reset button on the motor? Perhaps a surge when you turned it off popped the internal breaker.
View phiflint's profile
phiflint
22 posts in 2859 days
#2 posted 02-09-2013 09:08 PM
I bought the exact same model used. The same thing happened to me as soon as I got it home. I took the switch apart, cleaned it, & put it back together again. I think the switch or connections just get a little bit of dust or corrosion on them & they stop working. Give it a try. Good luck.
View rayn's profile
rayn
#3 posted 02-09-2013 09:29 PM
Do you mean the on/off switch on top of the arm? If so I may just try to jump it….Thanks
-- Ray,Iowa
View Jim Finn's profile
Jim Finn
2688 posts in 3163 days
#4 posted 02-09-2013 11:41 PM
Many DeWalt scroll saw users put clear plastic over the switch to keep the sawdust out of it. Using a floor switch helps but they too can fail because of sawdust.
-- No PHD just a DD214 Website> craftingcouple.com
View rayn's profile
rayn
#5 posted 02-14-2013 11:10 PM
I got it fixed today at the Dewalt service center..It was the switch…. Thanks to all
Ray
-- Ray,Iowa
