ReJapanning Planes - what do you use?
« back to Hand Tools forum
Forum topic by Ripthorn posted 02-09-2013 07:03 PM 2067 views 2 times favorited 27 replies Add to Favorites Watch
View Ripthorn's profile
Ripthorn
1454 posts in 2854 days
02-09-2013 07:03 PM
So I’ve got a couple planes that I am working on rehabbing/restoring and one or two are missing a lot of japanning (less than 40% remaining). I am not worried about collecting, but rather using. I have seen some people use actual japanning lacquer, but I don’t care to spend the time or money on something so specialized (not worried about being super correct). I have a can of black acrylic lacquer floating around, or I could pick up some kind of black paint. So my question to all is what do you use for re-japanning a plane?
27 replies so far
View Brandon's profile
Brandon
4152 posts in 2820 days
#1 posted 02-09-2013 07:18 PM
I really liked the black engine enamel in a spray can. It goes on nice and thick—just follow the directions.
-- "hold fast to that which is good"
View shampeon's profile
shampeon
1775 posts in 2052 days
#2 posted 02-09-2013 07:24 PM
A lot of folks go with Duplicolor Ford black engine paint, which you can apparently get at auto parts stores, and very closely mimics the look of japaning. I’ve used Rustoleum hammered black to give it some texture.
For a user, though, you could just brush some shellac over the current finish and metal. That will keep the exposed parts from rusting, and keep oxygen out of the nooks and crannies. The hard part about refinishing the body is stripping the old finish completely. If you’ve got a media blaster or are set up for electrolysis, that makes it a lot easier. Wire brushing it all off is dusty and messy, and it’s hard to get all the corners clean. Paint stripper will eventually work, but that’s also messy to clean up.
View Don W's profile
Don W
18554 posts in 2437 days
#3 posted 02-09-2013 07:50 PM
I use Dupli-Color Engine Enamel DUPDE1635 Ford Semi Gloss Black spray paint and here is my restore blog
If you want traditional japanning, look at jayT’s blog http://lumberjocks.com/JayT/blog/series/5621
Ripthorn
#4 posted 02-10-2013 02:42 AM
Maybe I will just got the shellac route, as I don’t feel particularly inclined to sand blast or otherwise get rid of the remaining japanning in the nooks and crannies. I admit it, I’m lazy :)
View JayT's profile
JayT
5488 posts in 2080 days
#5 posted 02-10-2013 02:58 AM
Any kind of spray enamel will work to protect from rust, it just depends on what you want it to look like. As far as stripping the old japanning, a wire brush works great and some aerosol paint strippers will do the job pretty easily and quickly, as well.
There is nothing wrong with a coat of shellac and then use the planes. If you decide to do more of a restoration in the future, you’ll have options.
View Tim's profile
Tim
3700 posts in 1830 days
#6 posted 02-10-2013 03:01 AM
I’ve been reading a lot on restoring tools, and the only problem with just adding shellac without carefully removing all the rust (which can be under the loose japanning) is the rust will just continue under the shellac. But if it’s truly just a user plane and you’re not too worried about that, you’ll probably protect some areas still.
View Francisco Luna's profile
Francisco Luna
943 posts in 3262 days
#7 posted 02-10-2013 03:02 AM
years ago, I tryed the original formula with asphaltum and taking the tool to high temperatures, but I can tell you’ll never get the same thing….
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View HorizontalMike's profile
HorizontalMike
7727 posts in 2783 days
#8 posted 02-10-2013 03:31 AM
I use Rustoleum Ultra 2X Semi-Gloss. Bought it at HD and it has held up well. I stripped everything with an electrolysis bath. Very easy to do and it it will take it all off. found it best to run the 12v charger at 10amps and at least 24hr or more.
Don W
#9 posted 02-10-2013 12:41 PM
Either way you need to remove the rust. You don’t want to encapsulate the rust. At least dip it in a rust remover like evapo rust or citric acid.
HorizontalMike
#10 posted 02-10-2013 01:19 PM
+10 on what Don says regarding the rust. Another method you can use if it is just a ‘user’ is to use RustFree from Boeshield, on the exposed iron. This stuff, while removing the rust, also seems make treated surfaces a bit more resistant to rust in the future. Not completely, but it does seem to stabilize the surface.
http://boeshield.com/features-benefits/rustfree/
Directions
For light rust on steel or cast iron, spray RustFree™ on a rag and wipe surface. Do not spray directly on surface, as it may cause spotting.
For heavy rust apply RustFree™ thoroughly wetting surface, allow to penetrate for 30 seconds, then scrub with Scotch-Brite pad before wiping off.
Caution
RustFree is acidic and should be used with care:
- Rinse thoroughly off painted surfaces and neutralize with soap and water.
- Do not use on guns or black oxide tools.
- Can dull paint or plastics.
- Can cause spotting on cast iron or steel.
Ripthorn
#11 posted 02-10-2013 06:51 PM
All planes in question have been de-rusted quite well. Just when I thought I would just put some shellac on, Mike goes and posts a picture like that, curse you! Now I might want to do a full blown restore, grrr. :)
Don W
#12 posted 02-10-2013 07:38 PM
Then if you’re on the fence, don’t look here
http://lumberjocks.com/topics/35888
View Benvolio's profile
Benvolio
148 posts in 1800 days
#13 posted 02-10-2013 08:52 PM
Just out of interest, what method do you guys use to take off the old layer of japanning before applying the new???
-- Ben, England.
View TheDane's profile
TheDane
5348 posts in 3532 days
#14 posted 02-10-2013 09:27 PM
Benvolio—I used a paint stripper from the BORG (Stripeze ?), then did as Mike suggested and gave it a 24-hr electrolysis bath. I did a thorough cleaning, masked the sides and soles, and sprayed with Ford engine enamel.
—Gerry
Don W
#15 posted 02-10-2013 09:55 PM
@Benvolio – http://timetestedtools.wordpress.com/bench-plane-restore-the-dw-way/
