looking for blade for a McGraw-Edison 10" Band Saw Model- T6760 16 Type -A
Forum topic by woodchic posted 02-09-2013 04:00 PM 10526 views 0 times favorited 8 replies Add to Favorites Watch
View woodchic's profile
woodchic
841 posts in 3409 days
02-09-2013 04:00 PM
Topic tags/keywords: band saw 10in mcgraw-edison model-t6760 16 type-a bandsaw
I am looking for blades for a 10” inch Band Saw that I got at a yard sale a long time ago. I looked the company up and the only thing I can find on McGraw-Edison is…...............light bulbs. I did come across someone else looking for blades for the same make and model but I didn’t see any helpful information on they’re post it fix it. So that being said I am sure there is someone in here that knows how to help me. Thanks in advance.:)
-- Robin Renee'
8 replies so far
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3578 days
#1 posted 02-09-2013 04:10 PM
Unless there is something special about the blade for your saw any brand blade will work if it is the proper length. Several of the big name woodworking supply stores (internet) also will make whatever size blade you need.
View cstrang's profile
cstrang
1832 posts in 3219 days
#2 posted 02-09-2013 04:11 PM
There is a local place here that makes bandsaw blades any size you want if you can’t find one you need, you just tell then the size and how many tpi you want and in a couple days it’s done. Rideout tool and machine is the name of the place, I’m sure if you google custom band saw blades you can probably find somewhere closer to you, hope you find something.
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
View lew's profile
lew
12145 posts in 3807 days
#3 posted 02-09-2013 04:12 PM
View Loren's profile
10476 posts in 3699 days
#4 posted 02-09-2013 04:30 PM
View Roger's profile
Roger
20929 posts in 2855 days
#5 posted 02-09-2013 05:23 PM
If you can measure the blade, you may be able to purchase by its length.
View mrdull's profile
mrdull
55 posts in 3431 days
#6 posted 02-09-2013 09:57 PM
Lots of people have already suggested having them made, I would only add that when I used to do that I had a welder friend who did his own for his medal cutting blades he could also do mine. I would run the adjustment out to use the longest blade possible, then if I had a premature break and the blade was still sharp we would shorten it an inch or so reweld adjust for the shorter blade and get more use from the same blade.
-- “Duty is the sublimest word in our language. Do your duty in all things. You cannot do more. You should never wish to do less.” General Robert E. Lee, C.S.A.
24031 posts in 3902 days
#7 posted 02-09-2013 10:27 PM
Robin, I get all mine made up because I have a riser kit installed making a non standard length. Never had a problem but I do get the higher quality blades.
View Surfside's profile
Surfside
3389 posts in 2225 days
#8 posted 02-11-2013 07:56 PM
Try asking help too in owwm.org . I purchase my blades on www.sawblade.com . Got great blades.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
