Kitchen Pullout Drawer
Forum topic by ptofimpact posted 99 days ago 406 views 0 times favorited 13 replies Add to Favorites Watch
View ptofimpact's profile
ptofimpact
158 posts in 483 days
99 days ago
Topic tags/keywords: kitchen pullout drawer question
Getting ready to cut some Baltic Birch Plywood for Kitchen Pullout Drawers, two questions if I may;
1-do the sides / front/ back get attached to the Top of the drawer Bottom, or to the sides.
2- Using a 140 tooth plywood blade, how do I limit splintering.
Thanks.
-- Pete in NC
13 replies so far
View johnstoneb's profile
johnstoneb
263 posts in 339 days
#1 posted 99 days ago
You can attach the bottom to the bottom of the sides but it won’t last long before the load in the drawer pushes the bottom off. Most drawers have a dodo(groove) cut around the inside of the drawersdes and front and back the bottom slides into the groove and is supported on all four sides. The bottoms are generally not glued in to allow moisture movement.
To control splintering, if you’re on a table saw keep the good side up. You can tape the kerf area on bottom side with masking tape and this will help some.
If you are using a portable saw good side down.
-- Bruce
View Gene Howe's profile
Gene Howe
3184 posts in 1595 days
#2 posted 99 days ago
Bruce has it right. But, with Baltic birch and a sharp 140 T blade, I would anticipate negligible tear out.
Please do not attach the drawer bottom to the bottom of the drawer sides unless this is a utility/shop cabinet. Even then, not a wise method.
View Dan Krager's profile
Dan Krager
714 posts in 400 days
#3 posted 99 days ago
+1 on each comment above.
Other methods to limit tearout are to score the blade path on both sides with knife cut. You can also take a very shallow pass, about 1/16”, then make the full cut.
No matter how light the load, a bottom attached panel for drawer bottom is not workable long term. If you can’t make the space saving dado cut, then at least glue and nail a small strip (1/4×1/4 minimum) around the inside perimeter of the drawer to rest the bottom upon.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com
ptofimpact
#4 posted 98 days ago
Thank you all for your time and expertise, and I shall take all advice and aply it going foward.
I wonder if Baltic is a good candidate for Box Joints on a Router table?
Dont have a table saw just a 20+ year old Craftsman circular saw…still cuts pretty good.
-- Pete in NC
Dan Krager
#5 posted 98 days ago
Nope. Not unless you back it up tightly with a scrap piece. It will blow out the back every time.
Don’t need a table saw nor the “slkill” saw. Lots of great furniture was built with a handsaw, chisel, plane and a good marking knife. You can make your own square. It is FAR easier to cut dovetails by hand than a box joint on a router table. At least I wouldn’t do it. I love box joints and use them frequently, but they are cut on a table saw jig like I show in my blog archive.
http://kragerwoodworking.weebly.com/1/post/2012/05/box-joint-small-wedge-jig.html
DanK
Dan Krager
#6 posted 98 days ago
Here is a photo of an LJ practicing dovetails. This is only his third effort (that he talks about).
http://i1233.photobucket.com/albums/ff394/my70hornet/BoxBoards/78A41750-A606-48F1-AEE5-909B324B0CCA-801-000000711DE3ADE8_zps4db24ae7.jpg
GO FOR IT!
DanK
ptofimpact
#7 posted 98 days ago
Dan, thank you again, I have saved the links you kindly shared, I am especially interested in your site with the box joint info. I have not tried hand dovetails, nor mortise and tenon, but have purchased a medium grade set of hand chisels. The only thing I have used them for is a handmade Marking gauge.
Thank you again, great site, Great site, Great Folks~
-- Pete in NC
Dan Krager
#8 posted 98 days ago
Pete,
If you have any questions, I’ll be happy to help best I can. Advice is free and sometimes worth as much. Here is another link that may help explain the box joint cutter. It depends on a table saw so I’m not sure how helpful it will be to you. If your router table has a miter slot a smaller version could be built.
http://s837.beta.photobucket.com/user/kragerd/library/Custom%20Wood%20Products%20Portfolio/Box%20Joint%20And%20Wedge%20Jig
DanK
ptofimpact
#9 posted 98 days ago
DanK, thank you once more Perhaps a question if I may. Been researching drawer slides, our uses will only require the Blum epoxy white slides, as we have a pantry for canned goods and heavy items.
What I am trying to establish is; the base cabinets are approx 23 1/2 inches from Back to Front of Faceframe…when I use Rear Sockets to attach the slides, how do I determine the length lost, due to Rear Sockets, so I can determine length of slides to buy?
Any direction appreciated.
-- Pete in NC
View Sandra's profile
Sandra
1277 posts in 241 days
#10 posted 98 days ago
Hi Pete,
I built a set of pull out cabinet drawers. Feel free to check out my projects. I’m relatively new to all of this, so mine weren’t anything fancy, but I’m pleased with the end product.
The biggest lesson I learned with the drawers is that nothing is square. In other words, don’t expect the bottom of your base cabinet to be parallel to the floor and don’t expect the sides to be parallel each other. No matter how square your new drawers are, you’ll likely have to adjust and shim.
Good luck, and if I can be of any help, feel free.
Sandra
-- No, I don't want to buy the pink hammer.
Dan Krager
#11 posted 98 days ago
I always have the hardware on hand to actually measure, or go to a place I can touch it. You should be able to get the specifications and mounting instructions from the hardware mfr if not the supplier.
I would be careful, too, to use drawer hardware that is heavier than the rating might suggest. I consider a drawer slide rated for 50 lbs a light duty drawer. I’ve never seen epoxy coated hardware rated higher than a light duty. It seems to me that you might need to consider heavier slides than you are suggesting. These pantry goods get really heavy. Even hardware rated at 100 lbs might be light for this application. This will be especially important if you are securing the slide only at the rear and front! I’d be reluctant to use this type with this heavy an application. Heavy duty (150-200 lb), full extension, secured along its entire length slide is the only thing I would consider.
http://www.rockler.com/product.cfm?page=1491
but they’re sold out.
DanK
Sandra
#12 posted 98 days ago
Here are the plans I used.
http://www.thisoldhouse.com/toh/how-to/step/0,,709890,00.html
ptofimpact
#13 posted 97 days ago
Sandra, thanks for the help and info, and yes, found out nothing is square so have to install with adjustments. Thanks for the link, am using something very similar from DIY site. Like you, not a cabinet maker, so fancy is not the result required, something functional, but not terrible to look at.
DanK, been looking on Rockler, but also Lee Valley has some prices better than the box stores, thanks again. The drawers will hold pots, pans, cookie sheets, paper goods, all the ‘heavy stuff’ is in a seperate Pantry with wire shelves.
-- Pete in NC
