my hegner 14" is one speed why would i need a saw with more speeds?
« back to Scrollsawing forum
Forum topic by liketosail posted 02-09-2013 03:23 AM 4344 views 0 times favorited 6 replies Add to Favorites Watch
View liketosail's profile
liketosail
31 posts in 1910 days
02-09-2013 03:23 AM
Help with this question?
And if I did want to have more speeds how should I go about setting the saw to do that?
View Dan Krager's profile (online now)
Dan Krager
3972 posts in 2204 days
#1 posted 02-09-2013 04:01 PM
Like,
I have scroll sawed for years with a single speed saw. There are many times when I wish the speed could be slower because of the nature of the material I’m sawing. Very thin material is hard to cut precisely with delicate blade at high speeds. Thin metal sheets (aluminum and brass) are hard to control. And plastic melts. Burning is a problem on some woods like cherry.
So, if you are never going to encounter those situations, don’t bother.
If you insist on doing it, you must first find out what kind of motor you have. Induction motors cannot be speed controlled without compromising the life of the motor, unless you are a genius electrical engineer. Universal motors are easily speed controlled with readily available controllers. Router, drill, and angle grinders are usually universal motors i.e. they have brushes. Larger machines like most stationary tools are powered by induction motors, . If you can afford to do so, you might be able to find a DC motor to fit, and they are also easily speed controlled. Some of the newer saws have speed control built right into them.
I’ve considered different size pullieys on my belt driven saw, but it is such a hassle to change them. Someday I will upgrade to a variable speed Excalibur.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com One should always prefer the probable impossible to the improbable possible.
View Jeff's profile
Jeff
6 posts in 1901 days
#2 posted 02-10-2013 03:45 AM
I’ve only been scrolling for a few years, but I quickly discovered the importance of saw speed! (In my case) as I progressed and continue to progress into more intricate patterns, it is increasingly harder to make really tight turns with only one speed. the thickness of your material is also a consideration.
Must agree with Dan above about the liabilities of trying to slow down a one speed. On my first scroll saw, a single speed, pinned end saw I cut only 3/4” stock. I recently went to a Dewalt 788. A little expensive, but it’s a Dream to use compared to my old Delta or Porter Cable. But NOT the cost of a Excaliber; I want one of those when I grow-up!!
Jeff
-- Make Sawdust; Not War
View Jim Finn's profile
Jim Finn
2648 posts in 2891 days
#3 posted 02-10-2013 03:43 PM
I have two Hegner saws. One is single speed 27 year old machine and the other is a four year old saw that requires belt movement to change speeds. I leave it set to one of the higher speeds and just adjust my feed rate to control the cut. I find no need for speed control. If you want to adjust the speed of your saw contact “Advanced Machinery” for help. They are the US importer of Hegners and are very helpful. I doubt you can control the speed of your saw because it has an induction motor, but you can ask them.
-- Website is https://craftingcouple.com/
View William's profile
William
9949 posts in 2812 days
#4 posted 02-25-2013 01:42 PM
The only time I ever slow my saw down from it’s highest speed is if I’m cutting something that is so tiny that there is danger of the high speed throwing it from my fingers. I’ve spent to many times on my knees on the floor searching for a missing tiny piece.
However, if you just happen to not have variable speed, there is another answer for that. If you’re cutting something too tiny to hold and there’s danger of it going through the table and flying off into never never land, grab a thin piece of plywood and make a temprary zero clearance cover for the table.
If you have a zero clearance insert anyway, all of this is unecessar. I’ve just had problems threading blades with zero clearance inserts though and don’t use them.
View MrsN's profile
MrsN
985 posts in 3495 days
#5 posted 02-25-2013 05:37 PM
the 14” hegnar can’t change speeds, you are stuck with just one speed.
I have the same model, and with practice you can get used to the single speed and never wish for a different speed. However, my other saws are variable speed (but not as smooth running) so I often find myself wishing I could turn it up or down a hair. Sometimes I switch saws just to cut that one part, but usually I just complain about it and get over it.
If you don’t miss the other speeds, don’t worry about it.
View boysie39's profile
boysie39
7 posts in 2038 days
#6 posted 03-07-2013 04:46 PM
Hi , I bought a Multicut 1 14” Hegner and had the V/S fitted before I took delivery it cost £140 extra .The saw is a dream to use .
-- Better to be 5 mins. late than dead on time
