Building a Router Table (Abrams?)
Forum topic by toddbeaulieu posted 02-08-2013 09:31 PM 1275 views 0 times favorited 4 replies Add to Favorites Watch
View toddbeaulieu's profile
toddbeaulieu
814 posts in 2968 days
02-08-2013 09:31 PM
Topic tags/keywords: router table
I believe my next project will be a router table. Since I really can’t spend any more money right now, I plan to use materials that I already have, including my Rockler lift kit and PC router. It seems to work just fine for me.
I think I want to do the Abrams-style table, probably using the design from Crestonwood.
My biggest complaint with my existing table is with the fence slipping mid-cut. I’ll be careful to incorporate better lock downs.
My second complaint is not being able to quickly micro-adjust it. I’d love to be able to nudge it – better yet dial it after a test cut, or while aligning it. As opposed to loosening up the knob on one end and trying to gentle nudge it and often going too far.
Third – I’m really thinking of not implementing DC under the table. I just don’t think it’s worth it. Here's a guy taking the same stance. The video’s a bit winded. ;)
I think the Abrams fence looks adequate, but it’s still early to make that decision.
I’d love to hear any feedback on this! Thanks all!
117061 posts in 3541 days
#1 posted 02-08-2013 09:37 PM
Sounds like a good plan.
View jdmaher's profile
jdmaher
426 posts in 2543 days
#2 posted 02-08-2013 10:31 PM
I considered building my own, but decided to buy an RT1000 instead. It’s quite like Norm’s, and has proved more than adequate for my simple needs.
Dial-in micro-adjusting is NOT a feature of my table, but I haven’t ever actually wished for that. Sometimes I wish for repeatable set-up, but that’s really more a matter of operation sequencing and (if necessary) a pencil mark, fit to prior cut, and a test piece. I suspect I’d do the same even if I did have dial-in micro-adjustment (i.e., fit, don’t measure).
On mine, the under-table dust-collection is just adequate. I don’t get chips in the air, but I do have to cleanup the router compartment when I’m done.
The biggest decision I had to make was whether to use a lift or just get a router with above table height adjustment. It turned out to be much cheaper to just get my Triton router, which has worked well. Maybe not fancy, but quite functional.
Bang-for-the-buck and craft time considered, I’m glad I bought rather than make, since I’d rather build furniture than tools. And I’m glad I saved the money on a lift to spend on buying wood.
-- Jim Maher, Illinois
View kdc68's profile
kdc68
2649 posts in 2240 days
#3 posted 02-08-2013 10:42 PM
toddbeaulieu….you got the material, lift, router, and the ways to improve the fence. You are well on your way to success.
-- Measure "at least" twice and cut once
View Rutager's profile
Rutager
27 posts in 2267 days
#4 posted 02-08-2013 11:01 PM
I built the Abram’s table and have been very happy with how it worked out- didn’t much care for the original fence, so I adapted it to use the Incra fence. I just can’t stand the “bump” method of adjusting anything. I’m a big believer in being able to use a knob to dial in a cut.
-Rutager
