Having a little Trouble with my R4512 -Can't align the knife with the Blade
Forum topic by fstellab posted 02-08-2013 03:51 AM 1998 views 0 times favorited 14 replies Add to Favorites Watch
View fstellab's profile
fstellab
86 posts in 2086 days
02-08-2013 03:51 AM
Topic tags/keywords: table saw alignment blade question tablesaw
Hi Folks,
Trouble with the R4512, I purchased some Bosch blade stiffener. Part of the install calls for re-alignment of the the knife. Seemed like a easy process, and it worked fine for a few days.
The, I noticed that that the stock kept hitting the knife, so I repeated the process. Now I can’t get it aligned.
Any help would be greatly appreciated.
Cheers
-Fred
-- Fred Stellabotte (kamado@comcast.net)
14 replies so far
View nwbusa's profile
nwbusa
1021 posts in 2287 days
#1 posted 02-08-2013 04:44 AM
There are two 4mm hex bolts right next to the riving knife, on the left as you face the saw. Loosen them, adjust the riving knife as desired, then tighten the bolts.
I’m not familiar with the Bosch blade stiffener. Does it install on the left or right side of the blade?
-- John, BC, Canada
fstellab
#2 posted 02-08-2013 05:00 AM
Both Sides of the blade .. very hard disk that is supposed to help very thin kerf blades, and it helps with noise.
So I had losen all 4 bolts .. ok I was only loosening the two larger ones.
Thanks
View RussellAP's profile
RussellAP
3104 posts in 2287 days
#3 posted 02-08-2013 05:09 AM
You can’t use blade stabilizers on both sides of the blade on a 4512, not enough bolt left for safety.
If you don’t mind my asking, why do you need a blade stabilizer. I use a freud thin kerf without one and it cuts like Michael Angelo.
View Matt Przybylski's profile
Matt Przybylski
546 posts in 2378 days
#4 posted 02-08-2013 06:00 AM
Depends on how thin the kerf of the blade is but if its anything below .09 then you can’t use the knife with it as that’s the width of the knife. If the blade is in between two stiffeners it would not be safe to use them with the knife.
-- Matt, Arizona, http://www.reintroducing.com
fstellab
#5 posted 02-08-2013 04:36 PM
Ok folks,
I will remove the stiffeners, It did work, there was plenty of room left on the bolt ..
but I was right edge of the alignment travel.
Is there a better knife available ?
Thanks ..
-Fred
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3183 days
#6 posted 02-08-2013 04:44 PM
I used to use stabilizers on my old saw but once I started buying quality blades I found I didn’t need them. I also only have 1 thin kerf blade but regular kerf blades work just fine and I find that thin kerf blades don’t realy give me any benefit. I suppose for low HP saws they would be an advantage.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
View knotscott's profile
knotscott
8018 posts in 3376 days
#7 posted 02-08-2013 04:58 PM
I would not recommend blade stiffeners for the sake of just having them….they can be an effective band-aid for other problems, but they’re not a cure, and really aren’t necessary on a saw that’s spinning true using good quality blades. What prompted you to buy them?
fstellab
#8 posted 02-08-2013 10:28 PM
Hi Folks,
yes .. Knotscott I did buy blade stiffeners for the sake of just having them .. I will not do that again.
I am a new wood worker, and I guess I wanted every advantage to take on a project with thin rips of expensive wood, and I will using this blade:
MODEL # DIA. TEETH ARBOR GRIND KERF RAKE APPLICATION
RS-25524-U 10” 24 5/8” ATB .079” 20 ULTRA-THIN 10” rip blade. Only .079” kerf. Fast and clean, even without stabilizer plates.
I hard time getting the plate on the motor side off, it was really stuck.
I aligned it again, much better, but it still needs some tweaking.
Am I going to have to buy a thin knife when I but the thin kerf blade on ?
View kdc68's profile
kdc68
2657 posts in 2277 days
#9 posted 02-08-2013 10:55 PM
fstellab – If thin kerf is your preference then keep in mind the thickness of your riving knife. The thickness should either be in your manual or the knife itself (or both). As long as the width of the kerf on your blade is wider than the riving knive, I think you will be fine
-- Measure "at least" twice and cut once
View aaroncgi's profile
aaroncgi
33 posts in 1977 days
#10 posted 02-08-2013 11:34 PM
Here are the riving knife and resulting required blade specifications for the riving knife on my R4512. I’m not sure if all R4512 are the same, or how close the RK actually is to what’s printed on it, so check the one on your saw. However, I think it’s safe to say that 0.079” kerf will be way too thin for the stock RK. I had a couple times when it felt like my rip was hanging up on the RK, and the blade at the time was 0.094” kerf (the minimum allowable). Fortunately that’s my combination blade. My ripping blade is 0.098”.
Anyhow, here’s what’s on the riving knifefe:
RK Thickness .090” (2.3mm)
and on the other side:
Blade Body .060” – .086” (1.5mm – 2.2mm)
Blade Kerf .094” – .126” (2.4mm – 3.2mm)
-- Aaron
knotscott
#11 posted 02-08-2013 11:41 PM
The RS-25524-U would be from Tenryu’s Rapid Cut series. Not quite at the level of their Japanese made Gold Medal series, but is a good rip blade. However it’s pretty thin relative to the riving knife.
KDC68’s point about riving knife thickness is valid…the blade’s width (0.079”), plus whatever runout it may have needs to be a tad wider than the riving knife, which I believe is in the 0.09” range. A regular 3/32” thin kerf blade would work fine. The ultra TK will spin a lot easier, but you’ll need a different riving knife that’s less than 0.08”.
fstellab
#12 posted 02-09-2013 12:29 AM
Folks,
I have really messed up things, I can’t align the knife and blade. I wanted to go back to a known working configuration, so a put a standard kerf combo blade, with no stiffeners. I can’t get to align. As you all probably know there are 4 screws, two large, two small when I think the blade in inthe right place I start tighening the screws. I troied srating with the small ones, as soon as I tighte, the balde move .. same thing staring with the large screws.
I tried clamping 2 triangles to hlds the blade in place, then tighten the screws, as soon as I took the clamp off, the blades came out of alignment.
Well, I will leave it tonight .. and go watch TV (the wood working shows on u-tube)
Thanks folks
kdc68
#13 posted 02-09-2013 12:58 AM
fstellab -Yikes… take a break and come back refreshed…good luck with it
fstellab
#14 posted 02-10-2013 01:55 PM
Hi Folks,
I was able to finally get it aligned.
The issue was the 2 big screws, when you tighten them (especially) the front screw, the knife moves.
I could hold the knife in place with my hand.
To fix, I cut a 2×4 and put it between the knife and the fence.
I used for several hours on Saturday, and the R4512 was back to cutting boards like they were butter. Then
I started some taper cuts, a board bound between my taper jig and the blade, which kicked the knife out of alignment.
I need to do some reading about taper cuts.
-Fred
