Has Anyone Sharpened Bits This Way?
Forum topic by DKV posted 107 days ago 443 views 0 times favorited 11 replies Add to Favorites Watch
View DKV's profile
DKV
2026 posts in 677 days
107 days ago
-- I would drink a river of the kool aid before I took the smallest sip of the tea...
11 replies so far
View Mark Kornell's profile
Mark Kornell
175 posts in 703 days
#1 posted 106 days ago
Yep. You screw it up the first 3 or 4 times you try, but you get the hang of it pretty quickly.
-- Mark Kornell, Kornell Wood Design
View Moron's profile (online now)
Moron
4443 posts in 2066 days
#2 posted 106 days ago
a gazillion times, works like a charm
the wheel can be cleaned up with a diamond point
View johnstoneb's profile
johnstoneb
268 posts in 345 days
#3 posted 106 days ago
Used to do it this way all the time when working in a truck shop. Works great once you learn how to do it.
-- Bruce
View DKV's profile
DKV
#4 posted 106 days ago
I will give it a try today. Wish me luck. If this works for me I am going to regret throwing away all those dull bits…
View PurpLev's profile
PurpLev
7764 posts in 1821 days
#5 posted 106 days ago
yes,
much like sharpening plane/chisel blades, once you get the hang of freehand sharpening the skill will go a long way down the road.
PurpLev
#6 posted 106 days ago
here are a couple of videos (step 1 and 2) with good explanation:
View DKV's profile
DKV
#7 posted 106 days ago
Thanks Purp, I will watch today.
View shipwright's profile
shipwright
3400 posts in 970 days
#8 posted 106 days ago
Always have, always will.
You can customize if you like too.
In boat building you sometimes have to drill long (measured in feet) holes in soft wood like yellow cedar. For those bits it’s nice to make them more aggressive in both lead and vee angle…. the work will go a lot faster.
Good video, it illustrates the technique well.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
View GT350's profile (online now)
GT350
111 posts in 154 days
#9 posted 105 days ago
That’s how I sharpen my bits, works great except I find the smaller the bit the harder it gets.
Mike
View REO's profile
REO
287 posts in 247 days
#10 posted 105 days ago
there is another way that makes it easier for some. place the lip vertically against the wheel and angle the bit slightly to the right at the shank end. this will help to ensure relief. it will also help break the chip in both wood and metal since the lip has a concave edge. a cheap drill angle check is two nuts held together. this forms a 120 degree angle. close enough to 118 degrees.
TopamaxSurvivor
13194 posts in 1848 days
#11 posted 105 days ago
Made the gauge in high school. Had to get 2 perfectly even spirals to pass drill sharpening. Even make my own brad points from old ones shaped like those in the videos ;-))
