Best shipping method
Forum topic by unisaw posted 02-08-2013 02:28 AM 1030 views 0 times favorited 8 replies Add to Favorites Watch
View unisaw's profile
unisaw
92 posts in 4099 days
02-08-2013 02:28 AM
I’m about to order a Rikon BS from Amazon and I’m not sure about shipping method or how home hobbyists deal with large, heavy items. The saw comes in one box and lists a weight of 251 lbs. I’m 61 years old and although I’m fit I don’t have access to resources to lift an item this large from the truck to my garage. My current shop has Grizzly tools that typically came in 2 – 3 boxes. I assume once I get it into my garage I can carry the parts to my basement workshop. I would pay a local mover to pick it up at the shipper if that is an option.
Suggestions appreciated.
8 replies so far
View Tedstor's profile
Tedstor
1643 posts in 2599 days
#1 posted 02-08-2013 02:55 AM
Amazon sells those saws with “free super saver shipping”. I don’t see why the shipper wouldn’t deliver the box to your door? Once delivered, you could then move it into your basement piecemeal.
View woodman88's profile
woodman88
144 posts in 2614 days
#2 posted 02-08-2013 02:56 AM
I bought my Rikon BS a year ago through Amazon with free shipping and the carrier had a liftgate and then wheeed it into my shop on a cart. I was shocked as I had 2 friends lined up to unload it
View BenI's profile
BenI
332 posts in 2144 days
#3 posted 02-08-2013 08:55 AM
Weight-wise, at a certain point there almost have to be a liftgate on the truck delivering it but it might not heard to check with Amazon and double check or try to add special instructions/notes on the order when you place it.
-- Ben from IL
View ellen35's profile
ellen35
2734 posts in 3398 days
#4 posted 02-08-2013 12:08 PM
Open the box and remove the parts… take them in 1 at a time. If I can do it, you can too ;-)
You can get liftgate service to get it off the truck. The company here on Cape Cod charges $35 and usually the guy will get it close to your door for that.
View Grandpa's profile
Grandpa
3259 posts in 2641 days
#5 posted 02-08-2013 05:30 PM
If you have to go to a freight dick to pick it up ….rent a U-haul with a lift gate. Those rent for a few dollars a day when it is local. Cheaper than owning a truck. LOL Good luck with your saw and congratulations.
View Loren's profile
10262 posts in 3614 days
#6 posted 02-08-2013 06:18 PM
That’s not a lot heavier than a water heater full of
sediment. With a hand truck it’s not a lot of
weight to move. Bigger inflatable wheels on the
hand truck make it easier to bump the load down
stairs.
View AandCstyle's profile
AandCstyle
3027 posts in 2223 days
#7 posted 02-09-2013 03:18 AM
I have unloaded heavy tools from my truck by laying them down with the base at the end of the tail gate. Then I lift the top end so the base slides off the truck toward the floor. It is just a matter of keeping the angle of descent balanced against gravity. The shallower the angle the slower it slides down. Ideally you will have a set of wheels under it. HTH
-- Art
unisaw
#8 posted 02-09-2013 03:50 PM
Thanks all. I remember ordering my Grizz tools years ago and the shipper was very limited in what they would do to get the item from the truck to the house.
