| Forum topic by JesseTutt | posted 104 days ago | 364 views | 0 times favorited | 6 replies | ![]() |
104 days ago |
Topic tags/keywords: flatten a board thickness planer remove twist on a board I have a 6” jointer and a 7” wide board that rocks. The board is hard maple 1 7/8” thick. I need to resaw a 1.00” thick piece from it. Since the board is wider than my jointer I can’t use it. I was thinking about applying hot melt glue along one side quickly flipping the board over and pressing it onto wax paper. The glue would temporary fill in the gap on the bottom side of the board so it will have a flat (sort of) surface. If I can temporary remove the rock I am hoping that I can run the board through my thickness planer. Will this work? -- Jesse, Saint Louis, Missouri |
#1 posted 104 days ago |
I’d say place wedges under the board to eliminate the rocking, and hot glue those wedges to a plywood base. It would be a quick and dirty way to duplicate results from a more elaborate and re-useable planer sled like this one. -- Brian in Arlington, TX - Laziness is the foundation of efficiency. |
#2 posted 104 days ago |
take the guard off your jointer, send it though and then hand plane the 1”. Or a router plane would work well. |
#3 posted 104 days ago |
It’s the old argument, you cannot flatten a board with a planer. But if you take very small cuts with the warp up into the cutters, often the rollers will not straighten out the board on a simple bow far enough to defeat the cutter action, and flattening does occur just like on a jointer. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#4 posted 104 days ago |
Brian, lumberJoe, Paul Thanks for the replies. I went ahead and tried the hot glue and it worked! When I pressed on the left back the right front only lifted about a 1/16th of an inch. so I just filled that side / edge and along the end with a puddle of hot glue and flipped it over and pressed hard on the back left. -- Jesse, Saint Louis, Missouri |
#5 posted 104 days ago |
A fancy sled as referenced by Brian is nice but if you need a quick solution just take a piece of 1/2 inch or thicker plywood slightly wider and longer than your work piece and use it as a temporary sled. Place your work piece on your bench, lay the plywood on top of it and add shims as required so it won’t rock. Then screw the plywood to the work piece in several places. Make sure you countersink the screws deep enough so they don’t protrude above the plywood. Obviously you need to pick screw locations that won’t be visible on your finished piece. Also the screw length must be short enough so they won’t get planed. -- Joe |
#6 posted 104 days ago |
I use a sled jig when planing stock wider than my jointer. The sled is nothing more than a strip of 8” wide plywood, with a cleat attached to one end. With a 6” jointer, this technique works well for up to 12” wide boards. No hot glue, screws, or shims required. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
221 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15769 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2838 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
