Block planes with adjustable mouths -- how often do you adjust them?
« back to Hand Tools forum
Forum topic by Furnitude posted 02-06-2013 05:10 PM 2167 views 0 times favorited 14 replies Add to Favorites Watch
View Furnitude's profile
Furnitude
380 posts in 3744 days
02-06-2013 05:10 PM
I’m in the market for a block plane. I’ve read the reviews of the Lie-Nielsen planes and the Veritas planes. I’m sure I can’t go wrong with any of them. They seem to be such high quality. My question is about the Lie-Nielsen low angle 102 – the one without the adjustable mouth. The 102 seems great for lots of things. Comparing the 102 to the standard block planes with adjustable mouths – i’m wondering how often I’d actually adjust the mouth. It’s probably set pretty thin. Cost is also part of the issue. I’m also wondering how necessary it is to have a heavy block plane like the 60 1/2 low angle. Does anyone have both the 102 AND the 60 1/2? Or can anyone comment on block plane preferences and how they’re actually used?
Thanks!
Mitch
-- Mitch, http://furnitude.blogspot.com Also blog at http://www.craftsy.com/blog/author/mitch-roberson/
14 replies so far
View b2rtch's profile
b2rtch
4868 posts in 3286 days
#1 posted 02-06-2013 05:16 PM
Every time that I need to, which an be quite often depending on the work I am doing.
This is kind of strange question.
If you have choice buy a plane with an adjustable mouth even if you really use it, when you need it you have it.
A block plane is one of the most used tools in a shop.n
Normally you have more than just one, I have at least five of them.
I personally prefer Veritas plane, not saying that LN are not good.
-- Bert
View Loren's profile
10477 posts in 3885 days
#2 posted 02-06-2013 05:20 PM
Not very often, but the ones lacking adjustable mouths are
usually too big in the mouth.
View Ripthorn's profile
Ripthorn
1459 posts in 3222 days
#3 posted 02-06-2013 05:29 PM
I recently upgraded from a fixed mouth to adjustable mouth and it has made a world of difference. When doing things like chamfers on open grained woods such as oak, it made all the difference between a nice smooth chamfer and something with bunches of tearout. I just set the mouth pretty thin and go my merrry way since I never use the block for hogging off wood. I do want to get a smaller “apron” plane at some point, but it’s not really necessary for the time being.
Furnitude
#4 posted 02-06-2013 05:47 PM
Thanks, everyone. Ripthorn, that’s exactly the kind of information I needed. I’ll do quite a lot of chamfering with the plane, so having the option to set the mouth very thin sounds important.
View Manitario's profile
Manitario
2703 posts in 3120 days
#5 posted 02-06-2013 05:51 PM
I have a block plane without an adjustable mouth; it sits on my shelf because it tears out the wood. Conversely, my LN with an adjustable mouth gets used all the time…
b2rtch
#6 posted 02-06-2013 05:59 PM
I believe that you should always get all the options you can afford.
Many time I bought a tool not knowing really why I was buying it but after having it, I found myself using very often.
I believe that an adjustable mouth on a plane, if available, is a no brainer as it offers so many more options.
-- Bert
View mds2's profile
mds2
310 posts in 2182 days
#7 posted 02-06-2013 06:00 PM
I adjusted the mouth on mine the last time I picked it up. Or “as needed”.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2348 days
#8 posted 02-06-2013 06:22 PM
More often than I expected… I’ll open up the mouth for heavier stuff, like looking at rough boards at the lumber yard or quick stock removal before I macine a board. I’ll close it way small for end grain and finer edge shaping cuts.
I also have some fixed mouth block planes that work OK, but if you CAN move the mouth, you can always choose not to…
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#9 posted 02-06-2013 06:59 PM
I adjust the mouth nearly every time I use it on my Stanley 60 1/2 low angle block plane.
-- Bondo Gaposis
View Don W's profile
Don W
19045 posts in 2805 days
#10 posted 02-09-2013 07:08 PM
Its like asking “How many time do you adjust your car mirror”. You may have only adjusted it once when you bought the car, but if you couldn’t adjust it it would be a life time of neck stretching.
That said, I adjust them a lot.
View bandit571's profile
bandit571
21994 posts in 2921 days
#11 posted 02-09-2013 07:35 PM
If you have a fixed mouth plane, low or standard angle, then you can set& forget the adjustable mouth ones. IF you have enough of them set each a little different, and grab as needed.
View stefang's profile
stefang
16209 posts in 3572 days
#12 posted 02-09-2013 08:38 PM
fairly often in my case for different tasks. What you really want to know is ‘IS AN ADJUSTABLE MOUTH REALLY NECESSARY?’ I can say yes in my case.
Gerald Thompson
1142 posts in 2472 days
#13 posted 02-09-2013 10:55 PM
I often times adjust my LV LABP a couple of times when working on a piece.
-- Jerry
View Francisco Luna's profile
Francisco Luna
943 posts in 3631 days
#14 posted 02-10-2013 12:37 AM
Lee Valley has great information regarding shaving types, that info comes with the user’s manual of their planes, Im sure they will send that info to you for free…..Mouth opening and blade angles are the most important issues on avery single handplane.
Why to move a frog on a conventional Bench Plane?....for the very same reason!
The answer is simple: to close the mouth. Tear out on many woods can be reduced significantly when having a tight mouthand it is esential for crossgrain work. Since Block planes and Bevel up’s do not have mobile frogs, thats why they have that mobile plate at front, that allows to close their mouth.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
