How to do a blog?
« back to Coffee Lounge forum
Forum topic by JoeinGa posted 02-06-2013 02:21 AM 740 views 0 times favorited 8 replies Add to Favorites Watch
View JoeinGa's profile
JoeinGa
7733 posts in 1913 days
02-06-2013 02:21 AM
Topic tags/keywords: blog separate parts adding to a blog question how do i
How do you guys (and gals) do these Blogs where you add each next part, and the links for each of the parts show at the top of the blog page, each with it’s own title (part 1. part 2, part 3, etc).
I started a blog on making my own disc sander and couldnt figure out how to do a “Part 2” so I just added a revision at the bottom.
And yes I did try to search to figure it out, but couldnt find an actual “How to” on this
8 replies so far
View Monte Pittman's profile
Monte Pittman
28189 posts in 2244 days
#1 posted 02-06-2013 02:25 AM
When you start a new blog entry there is a box for series. When you click on it, it will ask if you want to start a new series. Then name it.
-- Mother Nature created it, I just assemble it.
13594 posts in 3247 days
#2 posted 02-06-2013 03:06 AM
don’t put the number in the title
to the blog
the series will do that automatically
when it is posted
you can go back to the first you did
and edit
and do the series thing there
then come forwards to each blog that was done
and change them too
(they will also find their own series number)
till you get to the new one
and use the same series there too
it will pick up all of them that are in that series
each will be called by that series name and #
but each will have it’s own title
that you give it
like building the box
adding the top
doing the finish
etc.
JoeinGa
#3 posted 02-06-2013 03:11 AM
So can I go back and still do that on the one I already started?
http://lumberjocks.com/joein10asee/blog/34349
Or was I supposed to set it up BEFORE I started it?
View DIYaholic's profile
DIYaholic
19538 posts in 2581 days
#4 posted 02-06-2013 03:14 AM
According to Patron…..
YES, you can go back & make it a series and add to the original!!!
#5 posted 02-06-2013 03:18 AM
when you edit
you might have to delete the name you gave it
to open that ‘series’ window
do the thing there
and then just write the old post name back in
the next time you do a blog
you will have the options of continuing the series
or doing one not in the loop
View BRAVOGOLFTANGO's profile
BRAVOGOLFTANGO
281 posts in 1909 days
#6 posted 02-06-2013 03:27 AM
Thank you patron for this tip, I was also confused on my Pantorouter build and just edited the original. I don’t quite understand the purpose of having several series for the original but I’m new to blogging. Seems a bit complex for no more than what it is, but sure that’s just me.
#7 posted 02-06-2013 03:41 AM
at the top of each series blog
right over the title
are all those in that series
last on the left
current in the middle
and next to the right
so you can just go thru them all in sequence as you like
some series may have 8 or 10 parts
so this is the easy way to look at them all
without looking for a different one in the pulse
#8 posted 02-06-2013 03:49 AM
BGT
looked at your pantograph blog
you did the whole thing in one jump
many would break it up into sections
to be done at any later time
like a workbench build
that keeps getting setbck
waiting for the time or wood for it
to continue
the series can be added to at any later date
when it is convenient
by your bi-line
i would say you got a definite hit
with your first shot
well done
and a great build
