| Forum topic by richardwootton | posted 108 days ago | 423 views | 0 times favorited | 6 replies | ![]() |
108 days ago |
I picked up some Black Walnut yesterday and one of the pieces would be perfect for a book matched slab table top, the only problem is I doubt it will be thick enough to book match it. If I remember right it is 8/4 but it might be 7/4. Here’s a picture.
Thanks for the input, Richard |
#1 posted 108 days ago |
Well, you’re going to have to resaw it in half and you’ll lose |
#2 posted 108 days ago |
OR slice the entire thing into veneer and glue it onto a substrate. -- Made in America, with American made tools....Shopsmith |
#3 posted 108 days ago |
I am guessing there is a good change after resawing this that the 2 halves would want to move some and twist. I would resaw this to a thick veneer and install on MDF substrate if you want to capture the book matched grain across the entire length -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#4 posted 108 days ago |
Loren, The table top would be about six feet long. The reason that I’m entertaining the idea of book matching the slab is because I have a live edge about 6 feet long and I’d like to do a live edge table. Thanks, Richard |
#5 posted 108 days ago |
That’s a beautiful piece of walnut! I think you can get away with the modest thickness if you have an robust frame to mount the table on. You shouldn’t rely on just the top for strength, you need some sort of structure below. It would work. Even with resawing and planing you should be able to get a final thickness of 5/8” – 3/4” depening on whether you have 8/4 or 7/4 stock. That should do for a 6’ table, but I wouldn’t call it a “slab” table top.. Post a picture when you get the table finished! Note added: What is the dark round spot just under the end of the other board? Is that included in the 6’ of live edge? |
#6 posted 108 days ago |
you will clean up around or just below 3/4 depending on how good your resawing skills are, which should be thick enough for a top, if you think it needs to be stronger you can always put crossmember braces underneath to give it more strength but that should be unneccessary, However to make a good bookmatch, you are going to need to joint one of the edges, or it won’t really show up as a bookmatching. -- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15805 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
