how would (wood) you do this ?
Forum topic by SCOTSMAN posted 02-05-2013 08:43 PM 1098 views 0 times favorited 14 replies Add to Favorites Watch
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3826 days
02-05-2013 08:43 PM
Ok you cut a number of two inch forstner bit holes in a piece of timber so that you come out of the other side I.e leave a hole ( non blind hole).However you don’t want to leave the edges flat and desire to round off the edges to blend in like a doughnut with a hole in it not flat edges but as said rounded.How would you each go about this. Alistair?
14 replies so far
16281 posts in 4459 days
#1 posted 02-05-2013 08:47 PM
A roundover bit would be simple enough. Am I misunderstanding your question, Alistair?
View DIYaholic's profile
DIYaholic
19752 posts in 2916 days
#2 posted 02-05-2013 08:48 PM
I just did this not five minutes ago!
However, I used a bearing guided chamfer bit in the router table. Set the height and do a plunge cut in/onto the bit. If it is a panel, too large for the table, you can do it “free hand”, with a hand held router.
It worked for me, YMMV!
View Kreegan's profile
Kreegan
1452 posts in 2387 days
#3 posted 02-05-2013 08:48 PM
Chamfer or roundover bit in a router?
View AUBrian's profile
AUBrian
86 posts in 2912 days
#4 posted 02-05-2013 08:49 PM
Sounds like you just need to drill the holes, then use a router with a roundover bit and bearing to finish the job…
13641 posts in 3582 days
#5 posted 02-05-2013 08:49 PM
use a round over bit with a pilot bearing
in a router
do it from both sides of the hole
i hope this is what you are asking about
glad you are felling well enough to post again
and work in the shop
View MT_Stringer's profile
MT_Stringer
3183 posts in 3472 days
#6 posted 02-05-2013 08:55 PM
Roundover bit for sure. depending on the look you are going for will determine which size bit you use. I use the 3/8 radius bit a lot.
Here is an example.
SCOTSMAN
#7 posted 02-05-2013 08:56 PM
That’s not always practical what if you’re doing it in a piece in the lathe abowl etc. Alistair
MT_Stringer
#8 posted 02-05-2013 08:58 PM
“That’s not always practical what if you’re doing it in a piece in the lathe abowl etc”
You didn’t say that in your original post.
View DS's profile
DS
3046 posts in 2661 days
#9 posted 02-05-2013 09:01 PM
I’m sorry, I got distracted as soon as he said, “like a doughnut”
Mmmmm…. doughnuts….
What was the question?
View DS's profile
DS
#10 posted 02-05-2013 09:04 PM
So, I’m picturing a cylinder on a lathe with 2” holes drilled through the sides…
I think at this point I’m getting out my detailing knife and rounding the corners over by hand, then smoothing them with course sandpaper.
Patience is a virtue.
SCOTSMAN
#11 posted 02-05-2013 09:10 PM
I am sorry you are correct I never said it but I thought about it later and added it later.Just trying to cover every eventuallity.in other words the router is not the only way imho. And I wanted to hear of other ideas.Alistair
Kreegan
#12 posted 02-05-2013 09:44 PM
Use a Dremel or burr carving tool if you have one. Mebbe a gouge if you’re really careful.
View PASs's profile
PASs
595 posts in 3339 days
#13 posted 02-05-2013 10:32 PM
I’d go buy 10 feet of 120 grit sanding belt, cut it into squares, punch a 3/8 hole in the middle of them, put a bolt through the stack with 3/8 washers between every 2 or 3 pieces, tighten it down with a nylon lock nut, chuck it in a drill, turn it on, and slowly feed it into the opening working it in and out and around until I got the contour I wanted.
Or I’d use a roundover bit in a router.
BTW I have a roundover bit that fits in a hand drill. I actually used it to round the edges of a bookcase I made back in ‘85. It did need some cleanup sanding.
-- Pete, "It isn't broken, you just aren't using it right."
View Joe Lyddon's profile
Joe Lyddon
10374 posts in 4293 days
#14 posted 02-06-2013 01:45 AM
DITTO… router round-over
