Sander advice needed
Forum topic by 7bSkis posted 02-05-2013 08:53 AM 523 views 0 times favorited 1 reply Add to Favorites Watch
View 7bSkis's profile
7bSkis
2 posts in 1849 days
02-05-2013 08:53 AM
Topic tags/keywords: sander veneer
I am in the need of producing 6’ x 6” veneers around 1/32” thick. In looking at different sanders I find few able to sand that thin and the Jet/Powermatic drum sanders which claim to sand that thin seem to have a lot of detractors.
I am wondering about using a sled to carry the veneer through a sander that won’t normally sand that thin.
Any recommendations on units or techniques would be appreciated. My budget for a new machine is about $1000 but I would hope to find something used for less.
1 reply so far
View gfadvm's profile
gfadvm
14940 posts in 2598 days
#1 posted 02-06-2013 03:14 AM
I have used sleds (carrier boards) to sand thin stock but I think you will have problems attaching stock that thin to the carrier board. Double face tape will create a hump in stock that thin. The only option for attachment I see is spray adhesive (then you’ve got to ‘unstick’ it!) You could probably double face tape the ends only and then cut them off when finished sanding to final thickness.
