Old drill press?
Forum topic by pmd73 posted 02-05-2013 08:49 AM 1154 views 0 times favorited 3 replies Add to Favorites Watch
View pmd73's profile
pmd73
13 posts in 1911 days
02-05-2013 08:49 AM
i”ve got an old delta,10in drill press,3A.The chuck went bad on it and i bought a new stand up press.The motor is still good.I’m looking for ideals for what i could convert it to,too have another tool to woodwork with.What would an old drill press be good to make something out of.
3 replies so far
View RonInOhio's profile
RonInOhio
721 posts in 2834 days
#1 posted 02-05-2013 09:08 AM
You didn’t say what you don’t need.
My first thought would be a drum or spindle sander. Wouldn’t take much modification
There is a pneumatic sanding drum for drill presses that you can inflate to use as a drum sander. Let air
out of it and it conforms to the piece you are sanding. Not sure if you need the chuck or not.
You could also build a sanding table with a hole large enough for the drum to be recessed in. Hook up
a dust collector and you can sand curves without dust.
Woodworkers Supply, woodworker.com,
800-645-9292,
Pneumatic drum sander kit, including paper and base, #947-499.
I have seen some whacky conversions. Like converting a drill press to a verticle lathe. Doesn’t seem practical to me. A sander I would think would get a lot of use.
pmd73
#2 posted 02-05-2013 01:12 PM
I have a bigger drill press I use as a drum sander,built a box for it.I thought of making a sander of the old one,but as i said the chuck is shot and not worth the money to buy a new one.So i’ve got a small press with the shaft and motor.
View kizerpea's profile
kizerpea
774 posts in 2337 days
#3 posted 02-05-2013 01:19 PM
Thats what i did..sanding drum..an a dust collecting table to plug shop vac into…really good for sanding curves
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
