Drawer slides: full- or 3/4-extension?
Forum topic by Brett posted 02-04-2013 05:11 PM 6666 views 0 times favorited 19 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2767 days
02-04-2013 05:11 PM
I’m planning to build a shop cabinet with a bunch of drawers, each approximately 18” wide, 22” deep(front to back), and 3” to 12” high.The drawers will be used to store typical shop stuff: tools, boxes of nails and screws, cans of finishes, paint, etc.
I’m considering using 3/4-extension slides rated for 75 lbs. Will those be sturdy enough?
Are 3/4-extension slides adequate, or will I regret not using full-extension slides (despite the extra cost)?
-- More tools, fewer machines.
19 replies so far
View DIYaholic's profile (online now)
DIYaholic
19634 posts in 2759 days
#1 posted 02-04-2013 05:55 PM
As far as weight goes;
Get a bathroom scale and fill a comparably sized drawer and see what it weighs in at!
Personally, I would go with full extension, but that IS just an opinion!!!
View RockyTopScott's profile
RockyTopScott
1186 posts in 3562 days
#2 posted 02-04-2013 05:55 PM
I think you will regret not going with full extension slides.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
6860 posts in 4063 days
#3 posted 02-04-2013 05:59 PM
Full extension is almost always the way to go.
View doyoulikegumwood's profile
doyoulikegumwood
384 posts in 4076 days
#4 posted 02-04-2013 06:00 PM
i have to 3rd the full extension thing i know i regretted the 3/4 i put in my old shop new one has full.
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
View pintodeluxe's profile
pintodeluxe
5736 posts in 2897 days
#5 posted 02-04-2013 06:01 PM
I would use full extension slides. They will typically be rated for 100# for that size.
View DrDirt's profile
DrDirt
4426 posts in 3826 days
#6 posted 02-04-2013 06:34 PM
If it is a cabinet screwed to the wall – go full extension.
If you will fill the drawers with tools and screws – and think you may be “testing” the 75 pound limitof a cabinet on casters like Pinto – go 3/4 or your cart will tip when you pull out the drawer.
View Nicky's profile
Nicky
695 posts in 4176 days
#7 posted 02-04-2013 07:17 PM
DrDirt, good point about cabinet type.
If it’s non-mobile, I agree with the full extension slides that others are recommending..
-- Nicky
View Woodbum's profile
Woodbum
819 posts in 3149 days
#8 posted 02-04-2013 07:43 PM
Full extension. You can buy them in bulk from Woodworkers Supply. It is their house brand, but they work pretty well. Or you could get spendy and buy the Accuride full extension Plus 1” so the entire drawer contents are accessible.
-- "Now I'm just another old guy wearing funny clothes"
Brett
#9 posted 02-04-2013 08:30 PM
Whew, eighteen full-extension slides is no small investment. Thanks for the information, but I may need to rethink this…
View Clint Searl's profile
Clint Searl
1533 posts in 2445 days
#10 posted 02-04-2013 09:01 PM
Fancy drawer slides are expensive overkill
For my shop storage I put together a 2×4 frame with 2×2 drawer guide rails mounted inside.
The 22w x 24d drawers ride in the rails, which also keep them from tipping.
Brett
#11 posted 02-04-2013 09:09 PM
Clint, do the drawers slide freely, despite the slides being wood-on-wood?
View huff's profile
huff
2828 posts in 3369 days
#12 posted 02-04-2013 09:50 PM
Brett,
How much dust do you deal with in your shop? I would normally suggest full extension slides also, but I’ve used 3 different type slides in the different cabinets I’ve used in my shop over the years, 3/4 epoxy coated slides(very inexpensive), Full extension side mount (100lb. rated) and the Blum undermount full extension. (very expensive for shop use).
All have pros & cons, but the biggest problem I had using the side mount full extension slides was the dust and dirt getting into the ball bearings and working very rough over a period of time. If your shop is pretty much dust free, then you shouldn’t have that problem.
3/4 slides will bug you at times when you’re trying to find things that got pushed to the back of the drawers.
I would think the slides would handle the weight in most cases unless you just load the devil out of them. I’ve never had a problem with weight in any of those drawers, just the inconvenience of dealing with the drawer only coming out 3/4.
The Blums have worked flawlessly even with all the dust in my shop, but again ridiculously expensive for shop use. The only reason I used them, they where some left over slides from a huge kitchen job I did.
Actually I’ve used wood on wood drawers in one of my work benches and they worked OK, but the drawers where fairly small and about the only thing they were used for was sandpaper, so I have no experience using them for larger items and weight.
-- John @ http://www.thehuffordfurnituregroup.com
View brtech's profile
brtech
1036 posts in 3006 days
#13 posted 02-04-2013 10:04 PM
http://www.wwhardware.com/kv-tt100-economy-100-lb-full-extension-drawer-slide-kvtt100/
22” for $5.91 a pair. 100 lbs, full extension.
Now, these are not accurides, but they are pretty decent slides at an excellent price
View longgone's profile
longgone
5688 posts in 3392 days
#14 posted 02-04-2013 11:03 PM
I use wood drawer guides and cover the wood with this low friction tape. Works fantastic…!
404 - Not Found
2544 posts in 3053 days
#15 posted 02-05-2013 12:24 AM
It’s good to be able to pull the whole drawer out and throw it on the bench for when you need to go rummaging for something. You can do that easily with wooden runners or piston fit drawers.
