which is the better saw Powermatic 63 or Delta 34-444
Forum topic by liketosail posted 02-04-2013 04:53 AM 7062 views 1 time favorited 34 replies Add to Favorites Watch
View liketosail's profile
liketosail
31 posts in 1938 days
02-04-2013 04:53 AM
I have both, but have not had the time to use them yet.
I know the Delta was made in USA and the motor is easily removed and installed back on and they both have the same inserts ….which is the best?
34 replies so far
View History's profile
History
399 posts in 1979 days
#1 posted 02-04-2013 06:13 AM
If I remember correctly the Powermatic 63 has smaller trunion rods, and the cast wings are an open web design. The Powermatic was probably built in the USA also so it’s probably a good saw. I have had a Delta 34-444 since 1995 when I bought it new, it’s been a very good saw.
View Woodknack's profile
Woodknack
11624 posts in 2377 days
#2 posted 02-04-2013 08:59 AM
I have a Delta 36-445 which is similar, been using it for over a decade with zero problems. Which fence is on the Delta? If it has the crappy skinny fence then keep the Powermatic. If it has the Unifence or Bies then keep the Delta.
View knotscott's profile
knotscott
8013 posts in 3373 days
#3 posted 02-04-2013 10:12 AM
Very similar designs. Fence, alignment, and blade choice will make far more difference than brand.
View SamuraiSaw's profile
SamuraiSaw
515 posts in 1962 days
#4 posted 02-04-2013 02:27 PM
Personally I’d stay with the Powermatic. The cast iron wings are better than the stamped steel on the delta. But as Scott pointed out, proper setup will be the key with either one.
-- Artisan Woodworks of Texas.... www.awwtx.com
History
#5 posted 02-04-2013 04:34 PM
Solid cast iron wings can be found for the Delta Contractor’s saw, if I’m not mistakin, the Unisaw solid cast wings fit the Contractor’s saw as well.
SamuraiSaw
#6 posted 02-04-2013 05:19 PM
Why spend the money when the Powermatic already has cast iron wings?
History
#7 posted 02-04-2013 05:31 PM
Because the open web cast wings that the Powermatic has are less desirable then solid cast wings.
View b2rtch's profile
b2rtch
4861 posts in 3046 days
#8 posted 02-04-2013 05:44 PM
‘Because the open web cast wings that the Powermatic has are less desirable then solid cast wings.”
Why?
-- Bert
10385 posts in 3645 days
#9 posted 02-04-2013 05:45 PM
I’d say the Powermatic, but with reservations for the
contractor saw model and age of the tool.
Webbed wings suck.
The reason is it’s too easy to mash a finger in the webbing
when, for example, putting a crosscut sled on the table.
You can tell yourself “well, I just won’t make that mistake”...
...but I bet you will. More than once.
... and it will hurt.
Powermatic has cruised on a reputation earned on very
good quality up into the 1980s. I don’t know if the
Asian-made Powermatic models of today are made to
the same standards. From what I’ve heard, they
don’t measure up.
SamuraiSaw
#10 posted 02-04-2013 06:58 PM
Loren,
Gotta disagree. I used Craftsman saws with webbed extensions for more years than I care to admit. It only took once or twice getting nipped to get into the habit of watching where I placed my fingers. Kinda like shooting a semi-automatic handgun. You won’t put your thumb in the wrong place more than a couple of times. I still prefer cast iron in any configuration over stamped steel. In this case, I certainly don’t see the need to go to that extra expense. The return on investment isn’t there.
I recently spent a lot of time evaluating cabinet saws, and chose the Powermatic. I would say the fit and finish is as good as it has ever been. I had narrowed it down to Powermatic, Delta, and Saw Stop. Delta is not the same company it used to be either, and I wasn’t willing to take a chance on them. The Saw Stop was just too expensive. I don’t regret my choice, and that saw runs 15 to 20 hours a week.
View oldnovice's profile
oldnovice
6849 posts in 3365 days
#11 posted 02-04-2013 07:24 PM
I have used both web and solid plus the cast aluminum ones …the aluminum ones I have (3) are for sale $15.00 each as they are just taking up shop space!
I prefer the solid because things don’t fall “through” like on the web ones and, they match my Benchdog solid RT extension.
Woodknack
#12 posted 02-04-2013 08:48 PM
I’ve never used webbed extensions and never want to. I’d rather make melamine extensions.
History
#13 posted 02-04-2013 11:32 PM
Webed wings also limit your choices for a good fence
SamuraiSaw
#14 posted 02-05-2013 12:05 AM
”Webed wings also limit your choices for a good fence”
Really?
Sorry Charlie (sounds like an old tuna commercial, huh?), but to use your own words you don’t have a clue. The Delta T2 and every version of the Vega fences (which are highly accurate and dependable fences) are recommended for and used on table saws with webbed extensions.
Perhaps these exceptional fences don’t meet your standards, but a significant number of hobbyists and professionals would disagree.
oldnovice
#15 posted 02-05-2013 12:12 AM
My fence worked fine with the web extensions! I just didn’t like the web openings as I could not get used to things falling through.
During the move to CA, I lost the rip fence alignment brackets for the wings so now I am limited in rip capability since the parts for my TS are no longer available!
The depth of my table is 27” and I have been able to get nearly any accessory but no parts for the original Craftsman fence. I have been thinking about buying a whole new fence …. when I get some shekels.
showing 1 through 15 of 34 replies
