| Forum topic by Charlie | posted 110 days ago | 774 views | 0 times favorited | 26 replies | ![]() |
110 days ago |
I just ran a calculation based on my current electric rates vs the cost of propane and was pretty amazed to find that electric is about HALF the cost of propane here. I pay 11 cents per KWHr. I used a simple calculator that compares the cost of 100,000 BTUs of heat from either source based on your local cost for each. $3.22 for 100,000 BTU from electric I had no idea there would be that much of a difference and I honestly thought propane would be cheaper. With the holidays and the cold weather, I haven’t been in my shop to work in WEEKS. I would love to be able to just keep it at around 40 or 45 when I’m not out there, and bring it up when I’m working. I can bring the AIR temp up real fast with a 35,000 BTU propane heater, but it’s noisy. And bringing the air temp up doesn’t do anything for all that cold iron out there. So ya have to bring it up and keep it warm for an hour or so before you can touch anything without stickin’ to it :) My shop is only 16×18 , but soon to be 16×24 when I build my wife’s garden shed and get her out of the shop building. She actually volunteered to give me that extra 6 feet if I build her a garden shed. I only have 2×4 walls so that’s all the insulation I could do. Seems fine once I warm it up. thoughts welcome |
26 replies so far
#1 posted 109 days ago |
Charlie, I use a big 220V electric radiant heater hung over the workbench and tool chests. Within an hour the temp on the thermometer moves from 32 to about 60. That’s not air temp, but the result of radiant heat striking the nearby surfaces. This quickly makes the tools easy on the hands, helps with condensation that would otherwise develop with air heaters. I LOVE it. DanK -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#2 posted 109 days ago |
Electric heat is 100% efficient, if you can keep it in the building, and is dry, to boot. If electricity costs are that low for you, I wouldn’t even bother with propane. Then again, I live in sunny southern California. I use natural gas for cooking and the clothes dryer. It’s WAY cheaper than electricity. I bought a gas dryer and stove not long after I moved in here, and they paid for themselves within a year. One thing to try is radiant barrier insulation in the roof/rafters of your workspace. It makes a huge difference in both hot and cold weather. |
#3 posted 109 days ago |
Hmmmm, something wrong with those figures, but I’m not sure what. We manage an RV park and our rates are 13¢/Kwh. Temps over this winter have been dipping to lower 20’s F. Depending on the preference of the site, normal cost is around $55-$75 per month for electric heat. If they use their standard 20KBTu RV furnace, they will go through a tank or maybe a tank and a half per month. These are 30 pound tanks, 5 gallons, cost is $27 to fill from empty. -- Improvise.... Adapt...... Overcome! |
#4 posted 109 days ago |
When you are comparing fuel costs, you must take into consideration more than just the unit cost of I looked up a chart that demonstrates what I’m trying to explain. The chart shows that for furnaces, the propane @ 78% efficiency costs less than a 98% eff. So cost will be determined to large extent on the efficiency of your particular propane heater. If the chart below is too difficult to see you can tap the control key and ”+” key to enlarge or |
#5 posted 109 days ago |
For me, being a boater and always worried about condensation, I have to tell you that, unless a propane heater is vented through an outside vent, it will produce more aitch-2-oh than you can imagine. Not a good thing in my shop. So, torpedo-type propane heaters can be a liability as far as I am concerned. Just saying. -- Captain Bruce, Washington State |
#6 posted 109 days ago |
If you can find a propane vented space heater that is ~75% or better efficient. It will likely @Charlie Your numbers don’t add up . A unit of electricity (kilo-watt-hour) typically only has around 3400 btu Propane has 90,000 btu per unit. So if I’m not mistaken, that translates to electricity costing 1/20 less for a unit than propane, typical cost per unit of electricity is ~ 12 cents per KWH |
#7 posted 109 days ago |
Propane is expensive. I switched it out for a heat pump and the slight bump in my electric bill is about 1/4 what I used to pay for propane. -- -- Rick M. |
#8 posted 109 days ago |
I purchased a Sterling ceiling hung vented 45,000 btu propane heater. I did most of the installation myself but hired a gas tech to run the line and pressure test it. Total cost for the heater, concentric vent kit, and installation came out just under $1000. I am very happy with this unit it does not make a lot of noise,and it is 82% efficient . Electric was not an option for me without upgrading the electric system in the shop. -- A tube of calk and a gallon of paint will make a carpenter what he ain't |
#9 posted 109 days ago |
Price per gallon on propane around here is about $2.78 and the calculator I used….. RonInOhio, you’re right… something doesn’t look quite right about the numbers. I worked in my old garage at the previous house with a natural gas heater mounted up near teh ceiling. Commercial type. And I have worked in a shop with radiant electric and I have to say I prefer how the radiant electric feels, but this is going to come down to a cost issue as well. |
#10 posted 109 days ago |
I can’t buy into those numbers. Electric gives you ~3400 BTU per KWH, LP about 94K BTU per gallon. In my case, electric is 9.75¢ per KWH, and LP about $2.00/gallon. LP is only 80% (+/-) efficient, so for me electric heat is about $2.90 per 100,000 BTUs while LP is about $2.75 per 100,000 BTUs. My electric cost is close to Charlie’s number, but LP must be really expensive to get that $7+ number, and that’s at 90% efficiency. I can tell you this, to heat my 24×32x8 shop so far this winter I’ve burned 74 gallons of LP. I have a meter to keep track of it. Last winter when it so warm, I burned 100 gallons the entire year. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#11 posted 109 days ago |
I wish I could bring a gas line from the street to my shop bu the cost would be around $5000.00 -- Bert |
#12 posted 109 days ago |
I have a 26×30 well insulated detached garage.. I heat it with a side kick(wood). If I load it once in the morning it will hold 55 for 24 hours. if I want it 80 for finishing I only have to load it 3 times in a 24 hours. |
#13 posted 109 days ago |
My shop is 24×30x10and also very well insulated but I have to load m,y wood stove all the time, I burn scrap wood. -- Bert |
#14 posted 109 days ago |
Charlie, from an up-front investment standpoint, you’re generally going to be better off going electric resistance. An electric baseboard or quartz (or other) radiant heat setup can be had (for what I assume your requirements would be) for probably $100. And electric is quiet and should be able to boost your 40-45 degree maintenance level up to a working temperature pretty quickly (and quietly). Ongoing fuel costs, however, are going to be high – just about as high as a propane or kerosene vented heater. Systems that cost less to operate generally cost more to purchase or require much more “hands-on” maintenance (refueling), or both. Something I’m considering for my shop is a high-efficiency ductless heat pump. I have (personally) installed two of them in my house and love them. The up-front investment is around $1,000 but they can produce heat at 1/3 the cost of electric resistance (which is what I’m replacing in my house). And they produce a/c in the summer. My concern, since they circulate/blow heated or cooled air in the room, is air filtering. I’m considering mounting the indoor unit inside a ceiling-mounted air filtration box, as I don’t think the heater’s standard filters would be able to handle a woodworking shop’s un-pre-filtered air. Here’s where I bought mine: http://www.goductless.com/ Edit: For anything 12,000 btu and under (not sure what your 16X24 shop will require), you can use a single 110 circuit. That might be helpful. -- From the fruit of their lips people are filled with good things, and the work of their hands brings them reward. - Prov 12:14 |
#15 posted 109 days ago |
@Dan, What brand are those heaters? -- Friends don't let friends use right tilt contractor saws...... |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15804 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
