Too Short Shelves
Forum topic by rhybeka posted 111 days ago 479 views 0 times favorited 14 replies Add to Favorites Watch
View rhybeka's profile
rhybeka
161 posts in 1294 days
111 days ago
Rather than getting stuck trying to figure out where I went wrong (still convinced the plans were wrong but oh well), I’m trying to figure out how to lengthen some plywood shelves, and wanted to run it past you guys to make sure I’m on the right path. The cut list stated to make the shelves 19 3/4 deep by 17 1/2 inches wide…well somehow my opening is about 18 1/2 inches wide even though I’ve followed all of the directions. Is my best bet going to be to rip some 1×3 into 3/4 lengths and biscuit/kreg jig/ glue/clamp it to the ply to get it to fit? I don’t believe these shelves are going to be holding anything significantly heavy (it’s for my SO’s craft area). So weight shouldn’t really be much of a factor. Or, should I just grab another sheet of plywood and rip new shelves? Thanks all!
-- aspiring jill of all trades
14 replies so far
View madts's profile
madts
667 posts in 512 days
#1 posted 111 days ago
I would do as you want to do. Glue is strong.
-- Thor and Odin are the greatest of Gods.
View DaleM's profile
DaleM
800 posts in 1556 days
#2 posted 111 days ago
Since it’s for your home, I would do what you’re thinking and rip a thin strip for each side, biscuit, glue and clamp and call it part of the plan.
-- Dale Manning, Carthage, NY
View renners's profile
renners
1898 posts in 1142 days
#3 posted 111 days ago
You could put a couple of screws in for good measure and plug them.
-- Do or do not, there is no try
View Tag84's profile
Tag84
466 posts in 829 days
#4 posted 111 days ago
put alot of dowels in the extra part together with glue maybe?
-- -Thomas -
View Dan'um Style's profile (online now)
Dan'um Style
10815 posts in 2155 days
#5 posted 111 days ago
cut the new plywood … a liability for future generations
-- keeping myself entertained
View Dallas's profile (online now)
Dallas
1883 posts in 660 days
#6 posted 111 days ago
plywood stretcher. That’s the only legal way!
View huff's profile
huff
2559 posts in 1458 days
#7 posted 111 days ago
rhybeka,
How are you finishing the front edge of your plywood shelves? If you ripped a little of the depth of your shelves, you could make a solid wood edge for the front and each end of the shelves. Miter the corners, glue and clamp. Your shelf will be plenty strong and would look finished on the front edge and ends.
Good luck.
-- John @ http://www.thehuffordfurnituregroup.com
View DIYaholic's profile
DIYaholic
7348 posts in 847 days
#8 posted 111 days ago
Yep, edge band the three sides, even if you need to redimension one side.
-- Randy-- I may not be good...but I am slow!
View RogerInColorado's profile
RogerInColorado
206 posts in 127 days
#9 posted 109 days ago
Amen to edge banding (half inch on each end) three sides.
rhybeka
#10 posted 109 days ago
Thanks all :) as soon as it warms up a bit I’ll be breaking out the table saw. I need to figure out how to make up a shelf pin jig too – off to search the forums :)
View MrRon's profile
MrRon
1575 posts in 1416 days
#11 posted 108 days ago
An easy fix. Rotate your shelves 90° and re-cut to 18-1/2”. The 17-1/2” width now becomes your depth. Add a 2-1/4”x18-1/2” filler piece to bring the depth out to 19-3/4”. You can place the filler strip either at the back or the front. This will be a much stronger shelf.
View ChrisK's profile
ChrisK
547 posts in 1254 days
#12 posted 108 days ago
Three biscuits would be strong and fast.
-- Chris K
rhybeka
#13 posted 97 days ago
Huh thanks Ron! I hadn’t thought of that! The shelves aren’t face framed, just edge banded from the look of it, so adding to the back may be my best option. Got a new to me craftsman table saw from my dad last night I’m itching to get cleaned up!
MrRon
#14 posted 97 days ago
Remember; there is always more than one way to skin a cat.
